161K views 146 replies 65 participants last post by  Leakyseals
Alrighty... I just replaced the fluid in my front diff, rear diff, and the transfer case.... and took a few pictures.
If anyone would like to see how I did it, read on.
(moderators, if this is in the wrong section, I humbly apologize)
Again, vehicle is a 2004 Escalade AWD, with 44,000 miles on it.
Before we start, let's note that I drove the front of the Escalade onto a set of ramps, and then jacked up the rear by the trailer hitch, and placed 2 jack stands under the rear area, to put the truck up in the air and level. I'm not that small, and I was able to crawl around under there with no problems.
Let's start with the front differential:
This is the drivers side of your front diff. Camera is being held near the drivers side front tire, shooting towards the passenger front tire.. looking across the front axle area, if you will.
You see two bolts there. The top one is bigger, it's a 15mm bolt. That is your FILL plug. The bottom one, the smaller one, is your DRAIN plug.
Always remove the FILL plug first, as shown here. (Don't drain it and find out the fill is stuck... that's no good.)
Fill plug is out, came out no problem. Now we remove the drain plug with a 13mm wrench. You're going to have your pan ready underneath this, because when this comes out, fluid will be draining.... the fluid will be shooting towards you a little, so factor that in your pan placement...
Fluid is draining... nice. So far, so good.
That drain plug is a magnetic plug, and hopefully you can see, there is a lot of material stuck on there....
Drain plug wiped off... lotsa stuff there. Hopefully, I did this in time. Honestly, if I had an Escalade with 25k or more miles, I would go downstairs and change that front diff fluid RIGHT NOW. Now. You're still sitting there.... get moving! Joking. Okay, moving along.... let's assume the draining is complete. Replace your drain plug, the 13mm magnetic one.
This is what we're going to use to refill the case. It's a little pumper, I have placed the correct length of hose on the pickup side, to go into a Mobil 1 75w90 bottle... I will put the long hose into the fill hole, and them pump the thing until fluid starts coming out the fill hole, indicating that the case is full to the plug hole... I've had that pump forever, I believe I initially purchased it at a marine dealer, and used it to fill up lower unit gear cases on outboard motors...
Like so. Ready to go.
Here we see I have started pumping, the fluid is flowing up the hose and into the case.
When it's full, replace the FILL bolt, the 15mm one, and you're done.
It took me around 2.5 quarts of 75w90 to fill it back up. An approximate number, there is probably some slight line loss with my long fill tube...
You're done with the front diff!! Congrats! Light a Marlboro, take a break, and get ready to move to the middle of the truck, down the centerline, behind the transmission.
Here we have the Transfer Case. This picture is shot from the rear of the truck, looking towards the front. Thus, this face of the case you are looking at faces the back of the truck. You see the two bolts there. It may not show up on the picture, but this case is actually inscribed "Drain" and "Fill". Same concept as before.
Now, you see the square holes there, and you're thinking "What size wrench is that??" Heh heh, good question.
There's your standard 3/8ths inch socket wrench, with no socket on it. Guess what?? That's the right size square.
Like so. Note that's the drain bolt... we're going to do the fill bolt first, as always.
Fill bolt is out. Case was really full, some came out. I was told at the Cadillac Dealer that that case is full of Auto-Trak II, the blue stuff. Which is $16 a quart. The factory fill, as you can see here, is ATF, Dexron III. So, save yourself some big cash, and just refill it with Dexron III (or Dexron VI) at a far lower price.
This is thinner fluid, so it will really gush when you pull the drain bolt, and it will be coming AT you, so watch it, and watch your pan placement, unless you want a faceful....
I'm sure you've got the idea here, Pull the drain bolt, let it drain, replace the drain bolt, set up your pumper, fill thru the fill hole until it comes out, replace fill bolt... These 2 bolts, like the front diff, came in & out with no problem.
This case took about 1.5 quarts to refill....
Pat yourself on the back, you have now completed 2 of the three cases!!
I've hit the picture limit, seperate post for the rear diff....
If there are mistakes here, I'm sure smarter people than me will point them out. You can save a pile of money here, with some easy work. Hope this helps someone... enjoy.
#3 ·
Thanks for your kind words...
Let me add one more quick thought. There are a lot of similarities in this write up to Tahoe's, Yukons, Trailblazers, Envoys.... they're very similar.
However, in some of those trucks, AutoTrak II, the blue stuff, IS REQUIRED in that transfer case, and IS the factory fill.... just a little note. Sometimes you need the blue stuff...
Not on the Escalade, apparently, but on some others, you do. Maybe because the Escalade is full-time AWD??? Not switchable, like the others?? Different guts inside that transfer case?? Speculating out loud...
Just an FYI...
#6 ·
BTW...I swapped the fluids on the front and rear diffs last night. Not too hard of a job...the truck was even sitting on the ground. I had some shavings on the magnetic drain plug that the dealer said is not a major concern. I hope he's right... The dude said noise/grinding sounds indicate a problem while the shavings normally accumulate. My truck has 64k miles on it and the stuff that came out was black...only about 1 qt in the front and 1 qt in the rear so it was time to do this job. Took just under 2 qts to fill the front and just under 4 to fill the rear. As for the rear level, there was a sign on a tag just above the rear fill hole that said the level should be 15-40mm below the fill hole. To achieve that level, I put a 90 degree bend in a plastic cable tie with 20mm of length hanging below the bend and used that as a dipstick. One word of caution when filling, it takes a little while for the fluid to settle. After I pumped in about two quarts in the rear, the fluid started flowing back out of the hole so I thought I had overfilled the case. After waiting 5 minutes, the level dropped and I was slowly able to add ~2 more quarts until the fluid registered on my makeshift dipstick. Great post Patrick.
See pics below for dirty plug and clean plug from the front diff.
#11 ·
PCGuy 760:
No.
You need Dexron III or Dexron IV...(or is it VI?? I always confuse that...) That's Dexron 3 or Dexron 6.
Or you can use the blue stuff from a GM Dealer, the transfer case fluid, but it's pricey....
#16 ·
I have an 03 escalade.
When I checked the level in the transfer case the other day, at least a half quart came out the fill hole......
As mentioned here before, how is it possible to overfill? Can that be bad?
Also I read here as well to use Dextron 3 or 6 when changing the fluid, that the escaldes did not use the blue stuff. My fluid is blue.
Does that mean I need to use the blue to replace it?
Thanks:bigroll:
#17 ·
Oldworld - You don't say how many miles you have on the truck... Is there a chance it was changed once already??
My understanding is that your 03 should be the same as my 04. My 04 had a factory fill of regular red Dexron 3. However, I *thought* it was supposed to be the blue stuff, so since I bought it already, I did go ahead and put the blue stuff in....
I am wondering if someone did that to yours???
If unsure, it will cost around $28 to go to a GM dealer and get 2 quarts of the blue stuff, which is a small price to pay for your peace of mind...
As far as overfilling, mine was slightly overful. That may have been due to the truck not being dead level while in the air... I'm not sure a slight overfill is a bad thing.
#19 ·
I have another thread on that, devoted entirely to the rear diff, which I think is also one of the stickies...
The short answer is no, loosen up half the bolts, on the lower half, put a drain pan under it, and pry it open slightly with something... big screwdriver, small prybar, whatever....
The fluid will drain nicely, and then you can just retighten the bolts you loosened, and fill it back up.
#22 ·
Okay, it's been almost a year since I did the Front Diff in the first place...
Some of you may recall from other threads that after I did it, it was still whining, and I took it back to the dealer, and they stood behind it and rebuilt the front diff... That was at roughly 45k miles, diff shot.
So now, it is 16k miles later. 16k miles on a basically new front diff.
First, let me say that you don't need the truck up in the air to do the front diff. I just did it no problem from on the ground.
Now, I pull the drain plug.... the fluid is toast. It's black, it's scuzzy. Only 16k miles on it.
The magnetic drain plug is covered with metal. Covered. Just like the picture earlier in this thread. After only 16k miles....
Hopefully this will help, this time I replaced the fluid with Mobil One 75w140 light truck/suv formula... I hope.
My new interval for front diff service is 15k miles. Obviously, this diff is eating itself, in daily driving... I think changing it more often can't be a bad idea.
So, if you have an Escalade AWD, drop what you're doing and change the front diff fluid now. The wallet you save may be your own...
#23 ·
i changed out the fluids out about a month after you made this post and i put around 4,000 miles on my car since the change and im changing it now out cause in going on a rally in june. the drain bolt for the front diff was covered in metal shavings, my fluid was black. so i agree w/ patrick7997 on changing it out more often.
my 03 has 26,900 miles should i be worried about the front going out?
#26 ·
Excellent information. Here is a pic of the front diff drain plug. 128K miles on the truck, no way of knowing if the oil had previously been replaced.
After much reading on this forum, I will dump the lower quality synthetic oil I put in and go with Amsoil severe gear oil 75W90 before winter. No noize or whine from the front diff so far...
