61 - 80 of 117 Posts
140 is a crazy number. When I first started changing my CTS tires I was incredulous as well.
Thanks again.. I'm going to be doing brakes/rotors in the near future and wanted to have the correct torque specs.
Another question.. does anyone know if there are torque specs for the caliper bolts and for the bracket that holds the caliper?
I'm not finding anything...
Tinman,
I noticed the chart you put up in #11 with the torque specs has changed to something else.
I'm glad I copied it and surprised it changed to something irrelevant to this topic.
BTW, I also added the CTS to the Alldatadiy subscription I have for my Eldo so I'm good to go.
Jim
Tinman,
Jim
Exactly why I told you to get on it immediately. This has happened before. Glad you got it in time. Unfortunately no one will be able to use it in the future.
Reactions: silversport
Hi Tinman,
Thanks again for the torque specs.
I did a complete brake job all around and everything torqued nicely.
I went with the Raybestos Coated rotors and their Hybrid pads.. brakes are nice and smooth and stop the car on a dime if needed.
It definitely needed it.. everything was original most of the pads were frozen in the clips..
hope this helps
ALLANTE 2 DOOR / ALL 1987 – 1993 100 ft-lbs
ATS COUPE 18″BASE / 2.0 TURBO 2015 – 2015 100 ft-lbs
ATS COUPE 18″BASE / ATS-V 2016 – 2016 110 ft-lbs
ATS SEDAN 17″BASE / 2.0 TURBO 2013 – 2016 100 ft-lbs
CATERA 16-INCH / SEDAN 1997 – 2001 80 ft-lbs
CIMARRON 4/DOOR / 195/70R14 1985 – 1988 100 ft-lbs
CT6 20″BASE / 3.6L 2016 – 2016 110 ft-lbs
CTS 16-INCH / BASE 2003 – 2007 100 ft-lbs
CTS 18″BASE / COUPE 2008 – 2013 140 ft-lbs
CTS COUPE 19″BASE / CTS-V 2014 – 2015 140 ft-lbs
CTS SEDAN – 2.0 Turbo 18″BASE / 2.0 TURBO 2014 – 2014 110 ft-lbs
CTS SEDAN – CTS-V V8 19″BASE / CTS-V V8 2014 – 2014 140 ft-lbs
CTS SEDAN 17″BASE / 2.0 TURBO 2015 – 2016 110 ft-lbs
CTS SPORTWAGON 17″BASE / 3.0L 2010 – 2010 140 ft-lbs
CTS WAGON 17″BASE / BASE 2014 – 2014 140 ft-lbs
CTS-V SEDAN / V8 2004 – 2007 95 ft-lbs
CTS-V 19″BASE / COUPE 2009 – 2014 140 ft-lbs
DEVILLE SEDAN / BASE 1965 – 2005 100 ft-lbs
DTS 17″BASE / BASE 2006 – 2011 100 ft-lbs
ELDORADO 2 DOOR / ESC 1986 – 2002 100 ft-lbs
ELR 20″BASE / COUPE 2014 – 2016 100 ft-lbs
ESCALADE 20″BASE / BASE 1999 – 2016 140 ft-lbs
ESCALADE ESV 22″BASE / ALL 2014 – 2014 140 ft-lbs
FLEETWOOD ALL RWD / 235/70R15 1970 – 1996 100 ft-lbs
SEVILLE ALL / SLS 1986 – 2004 100 ft-lbs
SRX 17″BASE / V6 2WD 2004 – 2009 100 ft-lbs
SRX 18″BASE / LUXURY 2010 – 2013 110 ft-lbs
SRX 18″BASE / SRX FWD 2014 – 2016 140 ft-lbs
STS – ALL 17″BASE / BASE 2005 – 2011 100 ft-lbs
XLR – ALL PLATINUM / CONVERTBLE 2004 – 2009 100 ft-lbs
XT5 18″BASE / BASE 2018 – 2018 140 ft-lbs
XTS 19″BASE / BASE 2013 – 2016 110 ft-lbs
XTS 19″BASE / BASE 2018 – 2018 125 ft-lbs
Nonetheless it's what the factory specs are.
Reactions: Long
Just responding to your personal opinion on 140 ft lbs.
We've had this thread before.
