Oxidized contacts at wiper motor connections causing failure, use dielectric grease?
3.3K views 12 replies 6 participants last post by  Ranger
Hey guys, small addendum to my wiper motor saga (85 Eldorado). Recently I'll turn the wipers on and they don't work. Fortunately, a quick disconnect of the connections at the motor and a spritz of contact cleaner works right away every time. Contacts appear oxidized. I want to do this the right way and get it over with once and for all.
The wiper motor contacts/wiring harnesses in the 85 aren't protected from the elements like newer systems. So I'm gonna give them a very light sand and cleaning. Afterward, I think I should use dielectric grease on the contacts, but since I've never used it I don't really know what it's good for. Internet research turns up contradictory information, but sounds like I should use it.
So, do I do my cleaning, then apply the grease over the connections after fully reconnecting the harnesses? (that is, not putting any grease between the contacts, just over them). Or put some on the contacts, then reconnect? Or doesn't matter?
Thanks!
scott
#4 ·
Dielectric grease does NOT conduct electricity.
It is a HD insulator, used mainly to prevent moisture intrusion into coil and spark plug boots - if the stuff was a conductor then the simple act of wiping it into a plug or coil boot would ground the spark directly to the plug shell or coil tower.
Read the packaging............. read the reports.
https://www.google.com/search?q=aut...+ignitin+dielectric+grease&aqs=chrome..69i57.11185j1j8&sourceid=chrome&ie=UTF-8
It allows the transmission of electrical force through a conductor while insulating it from adjacent metals or conductors ........
"dielectric" def.: https://www.google.com/search?sourc...6.0....0...1c.1.64.psy-ab..0.11.586...0i131k1j0i131i46k1j46i131k1.0.biOHd_mJtSA
#5 ·
Thanks Sub. Research is what's causing my confusion. CRC company (who makes the good contact cleaner) says squirt a big amount of dielectric grease into all contacts, then reconnect. Seemingly knowledgable others on the Internet say don't use it for anything except spark plug boots to prevent arcing.
#6 ·
That's the key to that sentence. IDK where they get the idea it's only for spark plug boots, but it's for ALL electrical connections. As a matter of fact, it's sometimes sold as "bulb grease" indicating use on bulb sockets.
#8 ·
Discussion confusing. If one fills a light bulb socket with the stuff (which I've seen recommended many times incl battery terminals) and then inserts the bulb socket, if it didn't conduct electricity wouldn't it have a negative affect on the quality of the electrical connection ? Why would one want/cause the base of the bulb to be "insulated" from the bulb socket ?
#10 ·
I said "mainly" in Post 4 - in the most common automotive application. You can use the stuff anywhere you want to reduce/prevent metal oxidation and moisture intrusion. Various exterior bulb sockets are a prime example.
The fuse boxes and snap connectors in my boat are well gooped - salt water and electricity don't mix well.
#13 ·
One of the most common problems on the late '60's Mopars is corrosion & oxidation on the bulkhead connection contacts.
Luckily, mine was in good shape even after 49 years, but I pulled all three connectors and brushed the spades and female connectors with dielectric grease to prevent any oxidation and have had no problems since.
P.S.
Photos are not my actual connectors. Mine where in better condition.
