41 - 60 of 168 Posts
On another thought, does anyone know if an oil analysis shows the levels of ZDDP remaining? I suspect not, but that would be a good indicator of how the OLM should be adjusted.
Yes. Oil analysis gives you a break down of the elements in your oil. An example:
Code:
 Element...PPM measured...PPM univeral average
Aluminum       2                      3
Chromium     1                     1
Iron     8                         14
Copper     3                     14
Lead     1                          4
Tin     0                           1
Moly     14                       55
Nickel     0                       0
Manganese     0                    1
Silver     0                          0
Titanium     0                     0
Potassium     0                  6
Boron     19                       37
Silicon     18                       14
Sodium     6                         10
Calcium     2984                     1978
Magnesium     10                    145
Phosphorus     1027                679
Zinc     1187                         826
Barium     0                           0
Zinc and phosphorous would be the ones that highlight the remaining life on ZDDP. Silicon will tell you whether your air and oil filter is performing properly. They can also point out whether your bearings are wearing abnormally fast. Just keep track of mileage before sending your oil in. And post the results!
Oops, sorry... I think I'm confusing my mobil's..... There is a series that allows you to run 5000, 7500 and 15000 miles between oil changes. (and they list this on the bottle). I guess I don't know what it's called then.
(or maybe it changed??)
The Mobil 5000 and 7500 oils are not synthetics. The 7500 might be a blend but I don't remember for sure.
Did a little digging and it looks like Valvoline Synpower Oil Treatment and also Engine Treatment have zinc on the MSDS and STP Oil Stabilizer says it has more ZDDP than any other additive.
www.valvoline.com
www.stp.com
STP oil treatment http://www.stp.com/oil_4cyl.html has roughly 2000 PPM of ZDDP.
On a Northstar, you'd have to add 3 pints in order to match EOS (3x more concentration).
And at ~$2.50 a bottle... you may as well splurge the extra dollar and get EOS.
The reason I point out the 4 Cyl treatment vs the other is that the basic Oil Treatment is very thick, and I dunno what would happen if you add 3 pints to your mix at every oil change.
I have no idea how much the "Oil Stabilizer" has, but the name alone screams of "Lucas" and frothy oil... of course my comment is unfounded, just an opinion.
Mobil 1 EP is the 15000 mile oil, it comes in several grades including, 5W-30,
10W-30 (pictured above) and 15W-50.
Mtflight,
Did this "Wise Man" happen to address the 15W40 weight as 10W30 is hard to find in diesel applications.
Yes, Ranger.
He said 15W40 would be be just fine. (make sure it's CI-4 and not the new reduced ZDDP 2007 CJ-4 -- they will make them concurrently for a while).
He said this was important for the direct acting rubbing element, flat tappets. Your car has roller finger followers... which don't require ZDDP to survive.
Lowered ZDDP level does not neccessarily mean more wear. ZDDP doesn't come into play until there is a failure of the normal lubrication film and metal to metal contact occurs. If your engine doesn't have flat tappet lifters you're pretty much immune. All this Henny Penny the sky is falling obsession about ZDDP is much ado about nothing.
I can't believe in my eyes. A diesel oil in a gas engine ? lol
:cookoo: :alchi:
:cookoo: :alchi:
Many diesel oils are fine for gasoline engines (rated both C and S). But many oils for gasoline engines are NOT (rated S category). So when you say "diesel oil", you should almost always keep in mind that it means "both diesel and gasoline" oil.
Thanks for clearing . I will take that .
Hello everyone,
One thing I noticed is that CJ is designed for "low sulphur diesel fuel".
http://new.api.org/certifications/engineoil/categories/upload/EngineOilGuide2006.pdf
I think this means CJ becomes acidic quicker than CI (at least in theory), not good for an aluminum engine if you want to practice long oil change interval. But I don't know how significant this is in the real life.
Aluminum handles acid pretty well. Put aluminum in a strong base and watch it disappear before your eyes.
LOL! Thanks for the laugh. That was funny.
This, I'm sure, is true.
I have neither the experience nor the knowledge that you do. What I do have is a ticking/knocking '98 Flat tappet Northstar.
My oil has always been changed at maximum by the OLM, and at minimum sooner than that.
I run it hard to clean the carbon and hopefully dislodge whatever is causing the tick/knock sound... but now that I know it's in the upper end--what else should I blame?
Let me quote the first two sentences of a recent Hot Rod article by Marlan Davis:
For the last several years, many engine builders and individual hot rodders have experienced a raft of seemingly unexplained flat-tappet camshaft lobe failures. As one engine builder puts it, "I've failed more cams in the last three years than I have in the last 30."
from http://www.hotrod.com/techarticles/engine/flat_tappet_cam_tech/index.html
And what do the big oil companys think? Do they care?
I think they're more concerned with meeting the latest regulations, than catering to the small subset that worries and is obsessed with "Henny Penny ZDDP concentrations are falling."
They assume, rightly so, that most people, know very little about the subject (and "let's keep it that way"), who think the latest, most expensive synthetic oil is what they should be flowing in their baby.
Do the big car companies care?
I think they'd rather see us driving a new car (for instance a CTS), with a roller camshaft, than to spend money educating the public to warn us that our older engines with flat tappets either need additives or Diesel oils with higher ZDDP.
Can you imagine what the EPA would say to them if they encouraged all the older engine owners to use more ZDDP?
Racing oils will always have high ZDDP, but they are not for "street use," and they're pricey.
I recall reading this statement that was posted by Ranger from the Guru:
"We would tend to be on the conservative side. If the oil life is counting down on a slope that would recommend a 10K change interval then there is probably 20K oil life before the ZDP is catostrophically depleted....not that you would want to go there...but reason why many people are successful in running those change intervals.".
