The correct answer to this question is...
Remove the stuff you bought and put the production parts back on.
The ONLY thing you gained by installing the aftermarket parts was the sound.
You lost HP
You lost torque
You lost fuel economy
You lost reliability
And most of all you lost $$$.
2 possibilities as to the problem.
1
oor fit and or poor installation has created an air leak between the MAF sensor and the engine.
This allows un-metered air into the engine causing your performance issues and setting all the codes (traction will be disabled with almost any engine code)
2: Poor design of the CAI itself creates turbulence or dead spots in the air flow in the system. Either of those will also allow unmetered air into the engine.
Think about this.
The seller of the kit you bought made all kinds of claims about what it would do.
If changing the intake would do all those things why wouldn't they make the production part that way? Why would GM not give you the extra "free" HP.
The production stuff is plastic because plastic doesn't transfer as much heat as aluminum.
The production stuff if shaped the way is is because they want smooth laminar airflow across the MAF sensor and into the engine.
Simple big round pipes may not do that.
