Unable to adjust clock--2008 STS wi Navigation
2 reading
341K views 1.3K replies 224 participants last post by  johnnyrocket52
The clock adjust screen will come up after touching and holding for a couple seconds the clock area on the screen but none of the adjusting "buttons" are functional.
This is happening after an issue last evening where the car would not start until after disconnecting and reconnecting the battery.
Even then I had to put the keyless start switch in accessory mode first and then was able to start the car.
Any ideas on the clock adjust issue as well as what may have caused the "no start" issue. Thanks in advance for any help.
#329 ·
My optimistic take would be that it is probably "soft coded" to epoch 1 (I should say "defaults") since that is the most sensible given that the entire design and sale of the car existed in epoch 1. So I think this behavior is possible:
- On rollover, i.e. a 0000 week, our clocks work and would set the time correctly when that setting is selected
- The date will probably be week 0000 of that second epoch (i.e. 1999)
- We should be able to manually set the date
- A manual GPS sync should still hold the date since it now knows it was in the third epoch (i.e. the epochs are predefined in the code, which isn't too much of a stretch, since they are known for all time at least while the 10-bit week code is used)
Not sure what I would bet on this but it certainly seems possible. Yes, this is the "everything goes back to normal and no update is required" scenario...
#333 ·
I have been following this thread, as I too have a 2008 STS with the same Denso unit. Unfortunately, I did not know about this Denso-programming debacle a few months ago, and neither did the dealership that disconnected my battery.
The GPS Week Number Rollover will actually be on Sunday the 7th (1024 weeks from 08/29/1999), and I am hopeful that even a (wrong) date/time (that can be maintained), may solve the GPS sync issue. The SAT movements are incremental, so location should be maintained, and sync up fast, as it did prior to December.
We'll see......
#334 · (Edited)
If we want to get exact:
From here: https://www.xyht.com/gnsslocation-tech/wnro/
"The second scheduled GPS week number rollover (WNRO) will occur, according the rollover info on gps.gov, at 18 seconds prior to the 0000Z boundary (Coordinated Universal Time) between April 6 and 7, 2019—around midnight GMT, or Saturday afternoon of the the 6th in North America. If a GPS receiver is running firmware or software that cannot resolve that calendar ambiguity, it could have a flashback to 1999—the time of the first cycle of 1024 weeks from the 1980 zero week."
That will be at 5pm on the US west coast, so late afternoon / early evening for most of us. Don't forget, you MAY have to disconnect your battery again (or it may happen on its own).
Also the GPS satellites relative positions change very quickly: https://sciencing.com/how-fast-do-gps-satellites-travel-12213923.html
"With the Earth rotating once every 24 hours, a GPS satellite catches up to a point above the Earth approximately once a day. Relative to the center of the Earth, the satellite orbits twice in the time it takes a point on the Earth's surface to rotate once."
That's why a receiver knowing the date and time is very important for quick finding and decoding. Otherwise it just takes longer because it doesn't know the most likely ones to be overhead at a given time.
#382 ·
I learned something new from this!!!
The earth rotates once every 24 hours... therefor, it is NOT flat! :worship:
#336 ·
Something funny happened today while waiting for the day to come where everything is back to normal again, my GPS has come to itself again.
After my mechanics had disconnected the frame wire to my GPS / radio unit, the GPS card has been quite oblique.
It has shown my location but it has been 50 - 60 km wrong.
But suddenly today it was in place, my time has not yet come into place.
But there is also just over 10 hours yet until it is April 6 here in Denmark, I can hardly wait ;-)
#351 ·
Is there an easy way to disconnect the navigation, or is there only the hard way to remove the ground wire?.
I have looked through the instruction manual to find a fuse for the navigation, but can't find a fuse called navigation, but now English is not my mother tongue either, maybe you call it something else.
I have had a night watch so I am now on my way to bed, maybe there is a solution when I get up, hope everyone gets a good day.
