So never experienced this before as I've always checked the pressure of my tires manually for years. When I took delivery of my 16 performance last week, noticed that the tire pressure monitor said my driver side tire was at 51 PSI and all the other tires kind of all over the place but nothing too off except the driver side front tire at 51psi. So I go in with my key and deflate it. It did not update on the cluster at all so I just assumed it would correct itself on the drive home. It didn't. I waited till the next morning when the tires were cold to get my tire gauge out and check all the tires. The computer still said around 50psi for the driver front tire. I go check it with the gauge and it's at 35 psi which is what's recommended by the sticker. I go the the passenger front tire which states 35psi on the cluster and when I go check it, it's at 50psi so it's backwards. I suspect that's what happened at the dealer, they kept inflating the wrong side because it was backwards on the instrument cluster.
Anyone experience this before and if so, how do I fix it?
