So, what's interesting when you look at both cars together, the DLO shapes aren't that dissimilar; interior measurements are so similar that the geometry can't have changed much. But yes, the front handle looks higher, more in line with the rear on a line that's more perpendicular to the ground and the prominently 'flat' body line below the DLO. The diminished rake is obvious, and there looks like more front fender between front tire and hood line. The perspectives in the shots used to compare below aren't perfectly the same, but you can see that the stance isn't as aggressive...mom-jeans at the front axle line - yep! lol. The flatter, more upright nose probably doesn't help things, either. 'Slab-sided' comes to mind...reminds me a bit of the A3/A4 in that regard. ...and maybe some of it's just a bad camera angle?The proportion that seems most off to me in both the CT4 & CT5 is the greenhouse. It's bulbous, it isn't raked, it removes any hint of attitude. Second worst proportion is the mom-jeans beltline, way to high with door handles too high and too far back. Then there is the lack of trunk shelf, cementing the impression that screams "I hike up my pants and so does my car".
In this comparison the differences dont look very pronounced and the CT4 is certainly more of an evolution of the ATS design in comparison to the CT5 which to me is a big departure from the CTS design. The CT4 is less offensive to me than the CT5. The CT5's greenhouse is Pontiac Aztek level fail.
I think the crux of why the designs aren't well received on this owners forum is they lack passion and an intangible element of attitude. It's as if the designers used CAD CAM software to "evolve" the previous designs but didn't add any designer flair, no "car guy" touches, no corrections when the program got proportions wrong.
The result is a sterile vehicle with little presence and few brand cues that simply does not get the blood pumping (for me anyway).
(Pay no mind to the fuel door on the wrong side of the ATS-V - the image is mirrored.)
Completely agree with everything being said. Its even a worse of a thought that GM is intentionally holding back this V model not only performance wise but aesthetically was well. The ride height is ridiculously high and the wheel arches aren't as pronounced as the ATS-V.The proportion that seems most off to me in both the CT4 & CT5 is the greenhouse. It's bulbous, it isn't raked, it removes any hint of attitude. Second worst proportion is the mom-jeans beltline, way to high with door handles too high and too far back. Then there is the lack of trunk shelf, cementing the impression that screams "I hike up my pants and so does my car".
Lol. This is what I think of. Straight on rear view is just a big block.The Aztek designer must be channeling his flair:
Wasn't the radio the only thing that worked on the Yugo?"now they just need to continue to build the infotainment system with the reliability of a Yugo."
Lol!
The funniest WSJ article I have ever read was about the Yugo. Quite a few of them were imported into Canada and after many customer problems the Canadian trade rep called his Yugoslavian counterpart in for a consultation. He detailed many customer horror cases and my favorite was the customer who picked up his new Yugo and tried to fill it up on the way home from the dealer. After pumping in more fuel than he thought the car was supposed to hold he stopped and then found he had filled up the interior of the car with fuel because the connection from the filler opening to the tank was only connected at one end. Another customer had the windshield wiper control and motor repaired 5 times in one month. After the Canadian rep spent most of an hour describing similar cases with no real resolution, the Yugoslavian rep informed him that in his country people weren't allowed to drive cars which they couldn't repair by themselves and he felt the Canadian drivers needed to become better mechanics. Perhaps his son went to work for Cadillac.Wasn't the radio the only thing that worked on the Yugo?
My favorite Yugo joke was that it had a rear window de-icer so your hands didn't get cold while pushing it.
[Automotive News]"There was, frankly, some people who were intimidated by the cars," GM President Mark Reuss said after unveiling the cars last week. "When we did a V series, they were hammers. … There's some intimidation there."
I'm pretty sure the CTS can be optioned with AWD and MRC, so I wouldn't think it is a packaging issue.I thought similarly about the MRC. Got interested when in one article it mentioned MRC and AWD available, and then disappointed when the whole story was described in another. Do you suppose it could be a packaging problem (tight space) for both AWD and MRC, or is it just another bizarre poor choice by Cadillac?
That AWD 3.6 weight number might be pre-refresh. The 2016-2018 cars weighed a bit more due to structure changes and start-stop equipment - per C&D, a 2013 Premium RWD 3.6 weighed in at 3561 lbs and a 2017 weighed in at 3662 lbs. If the 3616-ish lbs for the RWD CT4-V hold for the real world, it is a slight weight loss.- CT4 is likely heavier: CT4-V RWD 2.7T is 3616 lbs., where ATS 3.6 AWD was 3629 lbs./2.0T RWD was 3373 lbs.
Weight should be about the same as the Premium RWD 3.6L - see response above. And less peppy, but a lot more torque - as long as lag isn't too bad and throttle response is good, I wouldn't be surprised if the new 2.7T is making 50-100 lbs-ft more real world torque between idle and 5000 RPM over the LFX/LGX. Won't be as fun to run out as the 3.6L, but in the real world I honestly don't get a chance to use that last 1500 RPM in my 3.6L very often. Here's hoping it doesn't fall flat on it's face after 5000 RM!I have to say I love the current ats-v sooooo much more than this design. and the weight ugh. the new ct4 is a porker with a smaller less peppy engine. I dont really understand this.... were they worried about EPA shiz? not to mention that the back looks like a Chrysler 300...
Just because he was intimated by the ZR1 doesn't mean everyone else is intimated by lots of power. haha jkSome additional marketing spin that doesn't quite come across the right way. On justifying why the V-series was expanded/diluted:
[Automotive News]
Per GM, 2013 sedan weights: 3.6L RWD – 3461 lbs. / 3.6L AWD – 3629 lbs. ... 2017 sedan: 3461 lbs. (3.6L RWD) / 3629 lbs. (3.6L AWD) || coupe: 3530 lbs. (3.6L RWD) / 3693 lbs. (3.6L AWD)That AWD 3.6 weight number might be pre-refresh. The 2016-2018 cars weighed a bit more due to structure changes and start-stop equipment - per C&D, a 2013 Premium RWD 3.6 weighed in at 3561 lbs and a 2017 weighed in at 3662 lbs. If the 3616-ish lbs for the RWD CT4-V hold for the real world, it is a slight weight loss.
I'm sure it's retuned slightly for the CT4, but in the truck, the 2.7T's peak hp comes at 5600 rpm and peak torque falls off after 4000 rpm. I have no doubt that it will get up and boogie - a sub-5 sec. 0-60 is almost assured - but yes, throttle response and the soundtrack are big question marks....less peppy, but a lot more torque - as long as lag isn't too bad and throttle response is good, I wouldn't be surprised if the new 2.7T is making 50-100 lbs-ft more real world torque between idle and 5000 RPM over the LFX/LGX. Won't be as fun to run out as the 3.6L, but in the real world I honestly don't get a chance to use that last 1500 RPM in my 3.6L very often. Here's hoping it doesn't fall flat on it's face after 5000 RM!
