The COMPLETE, CORRECT, STS Interior/Exterior Light Bulb Application Guide
83K views 124 replies 48 participants last post by  Too Fast
After MANY weeks of searching, I finally have compiled 100% correct information for every light in the STS. Here it is:
Headlight (without HID) :
|O | -- 9005
|O | -- H11
| o| -- 192/194
Front Running Light / Turn Signal:
| | -- 3757
Fog Light:
|O| -- H3-55W
2 Front Side Marker - 194/2825
2 Rear Side Marker - 194/2825
2 Backup Lights - 3157
2 License Plate Lights - 194/2825
2 Front Overhead Dome Lights and 2 Rear Overhead Dome Lights - 194/2858
2 Under Dash Lights by your feet - 194/2825
2 Bottom of Door when you open - 906
This should be every light in the car. I will have my LED conversion finished later this week. Please sticky this, or put it in the FAQ and link to it. Thanks!
#6 ·
I have to replace a couple of lights & I'm a little confused. One of them you have marked as "192/194" and the other one as "194/2825." Is that designating 2 different bulbs for each or is that 1? For example, for the front side marker lights, do I say I need a 194 bulb, a 2825 bulb or a 194/2825 bulb.
Thanks,
Max
#7 ·
The items with slashes are the recommended bulbs for that application. If it says "192/194" then a 192 or 194 bulb would be the best match for that applciation. If they say "194/2825" you can use 194 or 2825. I know this is confusing since 192/194/2825 are all technically interchangeable, but the sizes mentioned are either what was found from other members here on the forum, or other members on cardomain or locally.
#10 ·
Good job, but just a couple points of interest;
My car ('06STS4) has a W5W or 2827 bulb for the small light in the corner of the headlamp assy. While it appears to be a 192/194 it is quite a different bulb. Unlike a 192/194 the W5W or 2827 is a Halogen, so if you were to replace just one bulb with say a 192/194 it will be slightly dimmer and not the same color temp as the other. People may want to check which is in theirs prior to replacing just one bulb so as to get a perfect match. Also the backup light bulb you have listed contradicts my manual. In the manual it lists it as a 3157K the K meaning it uses a Krypton bulb, not the regular bulb.
I have found over the years that while the bulb may fit the socket, the properties of the bulb can be vastly different.
Cheers and thanks!
#13 ·
Of course, I decide to try to change it on Sunday & the small marker bulb in the headlamp assembly is not available anywhere. It wasn't so easy to change without removing the bumper. I ended up snapping off the clips that hold the lamp in place. What do you think would be the best way to secure it back?
Thanks,
Max
#22 ·
Resurrecting an old thread for a couple questions. In the original post it says H3-55W for our fogs, when ordering HIDs will the 55w be too hot for such a small space? I'm planning on changing headlights soon should I get fogs as well since I will already have the bumper off or are the fogs easy to access with the bumper on?
