Wasn't there a TSB on this? I think there was at least for the 2000 and 2001s. If memory serves the ultimate solution was to replace the lower control arms with a revised design.
EDIT: Found it (originally posted by Logan Diagnostic). There are 2 documents, one relates to replacing the lower control arm and the other relates to a different type of caliper bolt:
There have been some new control arms released. People who have had the arms replaced suggust it does not fix the problem. Here is the TSB:
Shake/Vibration in Steering Wheel, Floor, Seat at Highway Speeds on Smooth Roads (Diagnose/Balance Tires/Wheels)
1998-2004 Buick Park Avenue, Park Avenue Ultra
2000-2004 Buick LeSabre
1998-2004 Cadillac Seville (SLS, STS)
2000-2004 Cadillac DeVille (DTS only)
2001-2003 Oldsmobile Aurora
2000-2004 Pontiac Bonneville (17" Tires only)
This bulletin is being revised to add the 2004 model year and delete the screened tire program information for all tire manufacturers except for Continental General. Please discard Corporate Bulletin Number 00-03-10-007E (Section 03 - Suspension).
Condition
Some customers may comment on shaking/vibration in the steering wheel, floor or seat while driving at highway speeds (typically between 60-72 mph (96-115 km/h)) on smooth roads.
Cause
These specific vehicles may be sensitive to various rotating mass assemblies, especially if they are considered to be out-of-balance.
Correction
Visually inspect the tires and the wheels. Inspect for evidence of the following conditions and correct as necessary.
Missing balance weights
Bent rim flange
Irregular tire wear
Incomplete bead seating
Tire irregularities
Mud/ice build-up in wheel
Stones in the tire tread
Set the tire pressure to 30 psi (205 kPa) COLD.
Road test the vehicle with the Electronic Vibration Analyzer (EVA) essential tool for a sufficient distance on a known, smooth road surface to duplicate the condition. Record the Hertz (Hz) reading as displayed by the EVA onto the tire data worksheet found at the end of this bulletin. This should be done after a tire break-in period of at least 10 miles (16 km) at 45 mph (72 km/h) or greater, in order to eliminate any possible tire flat-spotting.
If the road test indicates a shake/vibration still exists, check the imbalance of each tire/wheel assembly on a known, calibrated, off-car dynamic balancer. If any assembly calls for more than ÂĽ ounce on either rim flange, remove all balance weights and rebalance to as close to zero as possible.
Important
Some GM dealers may have a Hunter GSP9700 Road Force Balancer. This will simplify Step 5 by not requiring dial indicators. If a Hunter GSP9700 machine is available, it may also be used to measure the radial force of the tire/wheel assembly. A guideline here is 18 lbs or less.
While on the balancer, measure wheel runout. If radial or lateral runout exceeds .020 in (0.50 mm) for aluminum wheels (.030 in (0.76 mm) for steel wheels), replace the wheel.
After confirming wheel balance and wheel runout, if any changes were made, road test the vehicle again.
If the smooth road shake/vibration still exists:
Important
The completed worksheet must be attached to the hard copy of the repair order.
Record Radial Force Variation readings if you have access to Hunter GSP9700 Wheel Balance equipment. Use the worksheet found at the end of this bulletin to record the readings.
If one or more of the tires have RFV readings in excess of 18 lbs, match mount the tires to get below 18 lbs. Readings of 12 lbs. or less are preferable for critical customer concerns.
If the RFV can not be reduced to an acceptable level, replace the affected tire with one obtained locally.
The screened tire program is no longer in effect for Bridgestone/Firestone, Goodyear and Michelin. Low speed screened tires are available from Continental General only, and only for the Buick LeSabre.
Road test the vehicle to ensure the shake/vibration has been resolved.
Replace both lower control arms on vehicles built prior to the following VIN breakpoints. On Aurora, Bonneville, DeVille, Park Avenue, Park Avenue Ultra and Seville models, a newly developed hydro-bushing lower control arm with improved damping characteristics has been released. This control arm is not used on the LeSabre. The new lower control arms may provide an incremental improvement to the vehicle ride. Customers who have become "tuned in" to the shake condition may still feel some shake in the vehicle after the new lower control arms are installed. Refer to Lower Control Arm Replacement in SI (refer to the Parts Information table below for SI document ID numbers).
Important
THE CONTROL ARMS SHOULD ONLY BE INSTALLED ON VEHICLES IF, AFTER THE TIRE AND WHEEL DIAGNOSIS AND REPAIRS HAVE BEEN PERFORMED, THE VIBRATION CONDITION STILL EXISTS.
Model
VIN
Park Avenue
34175493
Seville (SLS, STS)
3U247643
DeVille (DTS only)
3U247644
Aurora
34175503
Bonneville
34175497
Parts Information
P/N
Description
SI Document
25746324
Lower Control Arm, Left (Aurora, Bonneville, DeVille, Park Avenue, Park Avenue Ultra, Seville)
Aurora -- 639351
Bonneville -- 657809
DeVille w/FE1, FE3 -- 724856
DeVille w/FE7 -- 724858
Park Avenue, Park Avenue Ultra -- 657760
Seville -- 539332
25746325
Lower Control Arm, Right (Aurora, Bonneville, DeVille, Park Avenue, Park Avenue Ultra, Seville)
Parts are currently available from GMSPO.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
E0901
High Speed Tire Shake
0.8 hr
Add
Measure Tire/Wheel Asm., Runout and Re-balance
1.3 hrs
Add
Replace Tire and/or Wheel - Each
0.2 hr
E3537
Arm Assembly, Front Control -- Replace
Use Published Labor Operation Time
Screened Tire Request Form (Bulletin 00-03-10-007F)
Fax Instructions:
Continental General : 888-847-3329
Here is the GM document 800385:
Support the brake caliper with heavy mechanic's wire, or equivalent, whenever it is separated from its mount and the hydraulic flexible brake hose is still connected. Failure to support the caliper in this manner will cause the flexible brake hose to bear the weight of the caliper, which may cause damage to the brake hose and in turn may cause a brake fluid leak.
Remove the brake caliper from the mounting bracket and support the brake caliper (2) with heavy mechanic's wire (1), or equivalent; do NOT disconnect the hydraulic brake flexible hose from the caliper. Refer to Brake Caliper Replacement - Front .
Remove the brake pads (2) from the brake caliper bracket.
Remove the brake pad retainers (1) from the brake caliper bracket.
Remove the brake caliper bracket. Refer to Brake Caliper Bracket Replacement - Front .
Mount the brake caliper bracket (1) in a vise.
Using a flat bladed tool carefully remove the pin bolt boots (2) from brake caliper bracket (1) and discard.
Remove the bushings (2) by carefully inserting a small screw driver into the brake caliper pin bolt bushing.
Rotate and pull the bushing outward to remove.
Important
Clean all parts in clean, denatured alcohol.
Dry with low pressure, non-lubricated, filtered air.
Inspect the brake caliper bracket for cracks. If cracked, replace bracket.
Installation Procedure
Important
When servicing a brake caliper equipped with the first design caliper hardware it will be replaced with the second design hardware. The second design hardware kit contains NIGLUBE lubricant and redesigned caliper pins. The second design hardware kit does not use bushings in the brake caliper mounting bores.
Using NIGLUBE provided in the hardware kit, lubricate the following:
Lubricate the bores (3)
Lubricate the inside of the pin boots (2)
Lubricate the new caliper pin bolts (4)
Install the new caliper pin boots (2) to the caliper mounting bracket.
Install the brake caliper bracket (3). Refer to Brake Caliper Bracket Replacement - Front .
Install the brake pad retainers (1) to the caliper bracket.
Install the brake pads (2) to the caliper bracket.
Remove the heavy mechanics wire.
Install the brake caliper. Refer to Brake Caliper Replacement - Front .
Document ID# 800385
Jim
