Hi @ all. Yesterday I noticed a big problem with my Eldorado (1977 FWD). After driving for aprox. 35min I parked the car to get some groceries.
When I came back I started the engine , put in "DRIVE" and, as usual, waited for the tranni to shift in the gear. but then I noticed engine power was not delivered to the wheels.
Put in "reverse", wait for the shift, and the car drove backwards normally. Put in "DRIVE" again , same problem. Put in Park, waited to shift, put in "low" - waited to shift and the car moved slightly forward. pressed the accelerator firmly , still not delivering engine power to the wheels, step off the accelerator and a loud crank - sound appeared. Then the gear was in and the car moved .
Put in "DRIVE" and I could hear the tranni shifting and the car drove, but it dodn´t upshift anymore. So I took the car home in what i assume was first gear.
At home I cheked the vacuum line for the modulator and that seems to be fine, checked the down-shift switch near the carb with an ohmmeter and that is fine,too. The filter and oil was changed 4 month ago.
Any ideas what I can check furthermore while the tranni is inside the car ?
Is it possible for "normal" people to pull the tranni out ? As fas as i understand the service manual there are no special tools required, but the tranny looks pretty big and seems like a pain in the .... to be pulled out.
About how far do i need to raise the front of the car to get the tranni out and how much is aprox. the weight of the tranni?
Any other thing I can do ?
Thanks,
Stephan
Thanks,
Stephan
