Srx 4?
21K views 10 replies 5 participants last post by  PJ1520
Could someone identify the 4 after the SRX on the tailgate? I though that it would designate AWD but would like to be sure.
I looked at a SRX with the 4 that was not AWD (I looked under the front end to be sure) and now there is an add for an AWD that states it is an AWD without the 4 after the SRX. While this badge could have been changed after repainting and cannot be depended on it may help in the search.
thanks
#2 ·
Yes, the 4 is supposed to mean AWD. But because you can buy them on Ebay for few bucks or remove it in less than 10 min, I wouldn't trust on it. But if you have the VIN number, the best way is to run option check on Compnine (http://www.compnine.com/vid.php) and look for MX7 option code.
MX7 is described as MERCHANDISED TRANS AUTO PROVISIONS, O/D, AWD (ALL WHEEL DRIVE) AWD A/TRANS PROVISIONS(MX7)
#10 ·
It is good to be able to check the VIN before even going anywhere.
One car was only a 2 hour drive but the other one is listed on ebay in Stafford, TX. Both cars state AWD in the add or listing but did not check out by the VIN. With such low build numbers a SRX V8 AWD that has the equipment I wanted will be very hard to find, too bad the one I was looking at was in such bad condition.
#11 ·
The ads are not reliable, as many of us have found out while looking. I can't tell you how many SRXs we looked at that did not have some listed option (or package) as advertised. The opposite was also true. When looking we stumbled upon SRXs that had options that were not listed in the ad!!!!!!!
The ad is only as good as the person/dealership entering the info. That is why the vin search is so valuable, before you get all excited or make a futile trip. A phone call to the dealership to verify? Also unreliable.
PJ
