popping/clunk noise sometimes when reversing
26K views 206 replies 11 participants last post by  sts 03
Just recently sometimes when I'm reversing I get a popping/clunk noise from the front.it does it as soon as I hit the gas.seems like it does it mostly when the wheels are turned when I'm backing into my parking.it doesn't do it all of the time but tonight it seemed to be alot louder.
#58 ·
The white part shouldn't - it's one side of a flexure bearing and should be fixed to the subframe. The aluminum arm itself will have some motion around it, though, since it's not a solid piece of rubber (it can't, it wouldn't be able to twist otherwise.)
If you feel up to it the arm it relatively easy to release, it just requires a lot of torque (and some creative thinking to not strip the special retainer nut).
#59 ·
It was moving more yesterday maybe cause the cause was facing downhill and today facing uphill, the white part is moving for sure its hard to tell from the pic but even in the second pic u can see the white part of the bushing is more exposed when the wheel is turned
#71 ·
Most of the time, driving on a crowned road, you will slightly turn the wheel toward the high side of the lane or road in order to keep the car from drifting into the gutter. Normal.
