People with the 2005+ Northstars: Do you have problems with oil leaks?
9.1K views 37 replies 18 participants last post by  curtc
I'm wondering if anybody has had any problems with the Northstar engines leaking oil at the half case seal? Reason im asking is because we are in the market for a new Caddy, and trying to decide if we should try a newer Northstar or go with the 3.6 (and possibly deal with the timing chain stretch). We had a 97 SLS with 205K, but its really starting to show its age, and it leaks oil like crazy. You can see smoke come out from under the hood when you park the car, the half case seal is shot. Boss also has a 1999 STS, and it leaks oil at the half case seal as well. We really love these cars except for that issue, and would love to know if GM has finally fixed this problem on the newer Northstars, so im looking forward for some of you to chime in! Thank you in advance.
#4 ·
The half case seal leak does still happen on the redesigned N*....But it isn't nearly as common as it was in the FWD variation, I've only seen a few threads regarding that in here.
As far as the 3.6 (both non-DI and DI variations) they not only like to stretch timing chains but they are much more notorious for drinking oil than the LH2 N* is...GM utilized a very poorly designed PCV system in those engines.
#5 ·
My wife & I have had our V8's for 4.5 & 5 years and our garage floor has been dry the whole time except for one leaky water pump on my car years ago (and a few Winter car turds). We have driven over 100,000 miles and think very highly of the N*.
Her car was a Hertz rental and does burn a little oil; less than a quart in 10,000 miles. She goes strickly by the OLM, ignoring the annual oil change advice in the manual. She gets it changed with new Mobil1 when alerted (about every 18 months & 10k). I check it when she gets back from road trips and add a sip when it's low. (It's her car. Why fight forces of nature?)
My car was broken in by some wonderful person in northern Wisconsin who had the dealer change the oil 4 times at 3,000 mile intervals to break-in my N* for me. I have the service record. It now uses virtually no oil and I don't spare the throttle. See the 'sticky' thread at the top of the forum. It's true, this N* thrives on WOT & compression braking.
It's fun, too!
Members also report cam & ring issues. They aren't as frequent, but there's nothing like catestrophic oil loss to ruin a trip. This forum contains multiple such reports.
If you like the V6, that's fine, but do yourself well and check the oil often.
#6 ·
Thanks for your input. Its a bit frustrating because between the two engines you are deciding what kind of problems you are willing to tolerate. I didn't learn about the 3.6 oil consumption til now, and now im really averse to getting a GM car with the 3.6. Its frustrating because we really love the look of the Cadillac and there is nothing else on the market like it, but after our experience with the Northstar we are hesitant in having to deal with the half case seal again. Not an easy choice...
#8 · (Edited)
I'd tolerate a weaping half case seal over worrying my timing chain might snap at 70MPH anyday....Let's see, buy some Mobil1 once in a while or buy a new engines if the valves bend and cylinder walls score...hard decision...
#9 ·
Bob K can't shake the mis-information that the 2005 & up 4.6 Northstar uses excessive oil. IMHO, there is no real pattern of this, even when abused. Some examples will burn a bit but very few leak. Most engines burn a little, especiall when producing like power & torque.
It's only real shortcoming is that it only gets average mileage. (It was expensive to build, but that's moot now!)
#12 ·
^^^ I do not disagree. My wife & I took her car on a trip to visit Mom today and got 24.5 mpg. Once before trashing the rock-like Michelin Energy tires that hers came with, we ran a full tank at around 80 MPH (2,000 RPM) and got 25 mpg calculated.
As Curt observes, I'll take that. It's not bad considering the STS is a 2-ton Luxury Sport Touring Sedan with over 300 HP & 300 Ft/lbs Torque. But some competitors are a bit more stingy on gas. I know of a car costing about $80k that makes almost 400 HP & gets 30 mpg. I do not want to trade; even at $4, just $1,000 still buys 250 gallons of gas. "Not bad" is not a slam; it's merely OK.
#13 ·
Your wife's is rwd and yours is awd correct?
The 273 rear in the base rwd v8 will net good mpg while the awd with its greater mass and 323 gearing will eat fuel like a fat kid eats cupcakes.
I don't mind it. The toys and power are worth the trade off to me. I've never had an Eco car, ever. Always a GM V8. Not to mention with PA winters and my other car an SLP SS Camaro I wanted something which would prove to be a tank in snow. My STS4 has passed many a SUV and truck stuck in snow.
#15 ·
Well, I have 190K miles on my '06 and it does leak oil a bit -- apparently from the cam covers because it is running down the side of the block onto the PS pump. I also see this starting on my 110K mile SRX, and even a bit on my 80K mile SRX. So yes, they will eventually leak enough oil to drip on your driveway, but not for a long time. Unlike my 140K mile '97 STS that burned/leaked about ten times as much
As for mileage, I have never seen 24 MPG on my 323 geared RWD STS, and right now it is averaging about 13 MPG with city driving. So safe to say mine eats fuel. Still, as others have pointed out, no one buys these to be miserly.
#23 ·
Love my new (to me) N* STS - 2005 purchased with 21,000 original miles. I have driven it about 3.000 miles in the last month, and am really glad I bought this car while examples like this are still out there. Oil leaks, well I drove Mercedes Benzes for many years, and head gaskets were pretty routine on the inline 6's and not uncommon on the V8's especially when approaching 200,000 miles. I hope I don't have oil leak issues again, but I wouldn't be frustrated with small leaks after my MB issues, and even if I have to replace seals or gaskets, the costs are pretty low compared to doing these jobs on the premier german cars. So get that Cadillac, drive it hard and enjoy it, knowing you have just bought one of the great performance/luxury values out there.
#24 ·
I recently had my engine serviced because of the case half seal. The shop tells me it's about 16 hours labour (I have an AWD so there is a little more time in mine) plus parts. Fortunately I had GMPP warranty that covered all but $100. Personally, I wouldn't shy away from the N* just for this reason. I love my car (except in the city the fuel economy is dreadful) and would not worry too much about a minor leak. As long as it's not a big leak, the cost of 16 hours labour can buy a lot of oil! Even when I had the leak, my oil consumption was minimal. I don't ever recall adding between oil changes, despite using the OLM which means longer intervals.
I have no interest in the 6 cylinder at all. My mother has one in her Enclave and I'm really not impressed. It's very low mileage and has already been in for some of the common items (including timing chain).
#29 ·
109k here, no oil leaks or real usage issues at all, last oil change interval I think I added a 1/2 quart over like 10k...My two previous Northstars (95, 01) leaked a good bit, the 95 burned it up pretty good too. AVG'ing 20-21MPG per tank since I got her at 71k. Easily the best Northstar I've owned to date :thumbsup:
#31 ·
Well I have to jump in. 2005 V8 1SG AWD. 194,000 NYC miles. No leaks ever on ground but my head gasket seeping bit. I will add a quart at 2500 miles and I change oil when monitor hits 40%.
Car looks amazing. I just put new battery in and set of Michellin all season tires last week. Only major issue I have is I need new MRC struts. Having tough time justifying cost on a 9 year old car with nearly 200 k miles.
Great car to buy.
#38 ·
Since 2005 a Cadillac has been delivering pizza for Domino's in my home town...I started the trend in my '95 STS part time for a second job, I then began working full time shortly after purchasing my '01...I left that gig in 2009, shortly after a co-worker purchased a '04 Deville, he has been delivering in that since...It's not every day you see a Caddy delivering your dinner :)
I actually had a guy reduce my tip at the door after he saw my car.
He says, "You drive a Cadillac!? You clearly don't need this."
I replied, "But sir, it is FAR from being paid for!"
:thumbsup:
