P275/45R20 on 1995 Fleetwood???
16K views 15 replies 7 participants last post by  CadillacPimpinNOLA
Anyone have any pictures or insight on some P275/45R20 on 1995 Fleetwood??? I currently have some 245/40/20 vogues, but I think they're too small for the Fleet. Will they fit with the skirts and how would they look???
#4 ·
Too small?!?
The 20 inch tires are really just a little larger than your stock tire size. They have a circumference that is three inches larger, which won't make much of a difference in the way the vehicle rides or handles (past any determent caused the smaller side wall.) The only problem you may run into is the tires being too wide; the 275 is the tread width. A tread that wide probably won't fit behind the fender skirt, and you may have problems is the tires rubbing. I would say try to find a set with a tread width 255 or below, and there shouldn't be a problem.
#5 ·
Another problem with mongo wide tires like a 275 width is they tend to follow grooves/ruts in the road. Unless you have a firm grip on the wheel, they'll pull you all over the place on a bad road. I had a car with 275/40/R17(stock tire size on a Camaro), it was pretty bad about that. Fine on that car though, because I drove it like a bat out of hell always with a firm grip on the wheel.
#8 ·
my friend has had everything on his 95 fleetwood from 14" spokes to 24" rims, hes had 22" vogues and as of right now i think he has 20" spokes on vogues. a 275 will fit without rubbing depending on the rim offset. he has airbags to to tuck the rims and the 24"s didnt rub, when he had the 22" vogues he had a 2" lowering kit and it didnt rub either
this is a 20" vogue layed out and the car is not cutup, it has factory fenderwells
this is layed out on 24"s and that tire is not only talled but much wider than a 275 tire
#9 ·
Now that's the way to reply to a thread, good looking out Bruh. But that's a show car, I'll be driving mine everyday. After seeing those photos, I actually think the P275 from vogue will work. I really wanted to see a FWB on P275/45R20 by Vogue. Well I guess those tires are for SUV's only. I'll call Vogue and see what they say. Thanks again
