Just had all 4 injectors replaced on my 14' 2.0T. OEM Delcos. After several years of monkey around with this vacuum line, that vacuum line, A/F sensor, O2, exhaust check (I do hv a ZZP), replaced coils, replacing plugs, injector cleanings. Everything was replaced and cleaned. NEW OEM cat. Most replaced by me. *Anyway, new injectors, not one misfire (if you've owned the car for sometime, you know what I'm talking about; intermittent stumble at idle). No more every once in a blue moon lean codes. Again, I repeat it has not misfired at idle one time in the past two weeks. Quite frankly, it should've been done when the car was new, but the dealer always told me they weren't finding any issue. I'm calling bullshit. I think that these newer injectors may have been updated. Shifts sharper under load. Always use high quality 93 octane. Purrrfect. I found a good private tech and I was able to get the parts relatively cheap. You're gonna need several gaskets and I had him replace the rail sensor and the crank sensor. Not a cheap job, it's 6 hours and they'll need to clean out the intake due to the direct injection residue. When he gave me the parts back, one injector looked pretty fouled up. Rail cleaning is great, but it's not always going to resurect these injectors because they're under such high load. Anyway, if you want it right, you have to bite the bullet. Most people I know just got rid of the car.
