Instrument cluster went off no lights
20K views 21 replies 14 participants last post by  STROSFAN2022
The lights on the instrument cluster went off, the Gauges stopped working too. Maybe a blown fuse? Where is the instrument cluster fuse located? Its a cadillac cts 07 3.6v . Thank you.
#3 ·
#4 ·
May be a ground problem. Check grounds underneath plastic door surround on driver and passenger side. Drivers side is close to parking brake petal but under plastic trim.
#6 ·
This info is for a 2008 N* but is probably the same.
Did you check G101 under the hood drivers side? The other end connects to the IPM- connector X3 pin #3.
and G200 on the left side of the instrument cluster near the a pillar.
Check under hood fuses: ECM/TCM IGN 15 A and EKM/I/P 10 A (may be labeled TCM/IPC)
Hope this helps. Good Luck.
#18 ·
I have the same problem and decided to remove the ground cable from the battery post for a few seconds and reinstall and the problem was solved for a while. I don't know what causes it but you can instantly reset it by removing the G cable and reinstall it, just incase it happens while driving. If anyone knows what causes it please let us CTS owners know.
#19 · (Edited)
Just had the same issue in my 06 CTS. Panel and radio went out. A/C and heat quit too. Blower was good but not cooling or heating. Also couldn’t unlock the doors or roll down the windows. I don’t know if it goes back to that recall issue with the key/ignition or if it’s as simple as maybe replacing the cluster panel relay.
