61 - 63 of 63 Posts
Hi, I am confused, I read somewhere in this thread that a diff from '16+ manual Camaro is interchangeable with the ATS LSD (G80) diff without having to do any modifications.
But other posts seem to say otherwise.
Asking because I have an broken diff and new bearing set is not available. Really hard/expensive (or do not ship to my country) to find a LSD diff (non-LSD plentiful, but do not fit my ATS Coupe Premium) for my ATS.
Camaro diffs are many more available and much cheaper. Although they do look very different.
So, is there a 3.27 LSD Camaro diff which fit my ATS 3.27 LSD straight away or with some minor modifications?
And what would be the part number?
Thank you.
PS also asked help in another thread, but hoping the Camaro diff is an option.
Post #52 seems to say what you need, I haven't verified anything.
The diff in my 2018 2.0 6MT is in the process of going out, and I just want to fix it without paying the dealer $3000 and waiting 6 months for my parts to come in.
To that end, I just ordered a used diff assembly from a 2017 Camaro 3.6 6MT to swap in (part number is 86827953, interchangeable with the Camaro 2.0 6MT). I'm going for the same ratio (3.27) and LSD like original. I believe I have found the right part to do that. I've been referencing this chart of all Camaro differential configurations:
2016+ Transmission/Differential Information - CAMARO6
Thanks David.
ProjectLtg literaly says it is one-on-one fit in pos #10.
But in other threads I read differently.
So I just want to be sure, and hope someone actually did the swap and can confirm the straight on fit.
PS I might be able to get the bearings to do the rebuild after all and don't need a new diff.
But I will not raise the flag until I have them in my hands and the diff properly running on my Coupe
#10 · Jul 7, 2021
If your current lsd fails you can buy a camaro manual 3.27 differential and it bolt right in. The ats and the camaro are to different designes but all mounts the same way....
Thanks David.
#10 · Jul 7, 2021
Hi @koppenolr, I'm in same situation as you (LSD for ATS is expensive in EU). Were you able to get the bearings for rebuild? Thanks
61 - 63 of 63 Posts
