some 1 said to my nearest gm dealer and show them my title and they can pull up my resistance number to my key,is this true? i need to know the sesistance because i need to bypass my vatts system
lmao.jayoldschool said:maybe it has the performance chip!
now im confused lol the picture diagrame on page 2 says ccm,thats what im talking aboutWhat you've described is the case with the PCM, not the CCM.
ok you dont seem to be listening very well we are trying to help you,93 has its own, 94-95 share the same an 96 is different.... from what i was told,you probly learned something new the fleetwoodguy:highfive:
in the picture above the 96 model c1 & c2 plugs do not plug in the 94 model ccmHere:
At the risk of beating a dead horse, the same exact picture appears in both the '94 and '96 factory service manuals. The description and operation of the CCM is the same, word for word, in both service manuals and (again) the connector face diagrams and wire pin-outs are exactly the same. Last, the part number of the connectors themselves (the C1 connectors) are exactly the same. I checked the wiring diagram because I've had scenarios where the plugs are the same but the wiring is different year-over-year. Not that I doubted thefleetwoodguy, but I wanted you to be confident that there will be no issue with the '94 CCM in your '96.in the picture above the 96 model c1 & c2 plugs do not plug in the 94 model ccm
Actually, I meant the exact opposite. The CCM is hard-wired to look for a certain value. Since you replaced the '96 CCM with the '94 CCM, having the dealer match the '96 VIN to the car's correct resistance value won't help. If you want to go to the dealer with your VIN and have them make you a key, you need to put your '96 CCM back in it. This might be the path of least resistance (resistance, get it? I kill me....).great info so you are saying i would need to bypass it with the factory 96 resistance not the 94s right,if i do need the 96 i guess i got to go to the gm dealership then
Sorry - I inadvertently took you down the wrong rabbit hole. Using the '96 CCM is probably pointless. Since you currently have a matched set of key and CCM from the '94 and it's still not working, that points to the ignition cylinder in the column. So what I would do is determine the resistance of the '94 key with a DVOM and buy that resistor at your local stereo shop. Then install it in the PASS KEY circuit as previously described.so if i get the 96 resistance i would need to put back the 96 ccm, so with both 94 ccm and column/key i could just get the resistance off the 94 then bypas it
