Front strut assembly
1 reading
4.4K views 20 replies 7 participants last post by  Spyderson79
I see a lot of non OEM options but don’t want to do this again anytime soon. Anyone have a suggestion for a quality full assembly with the spring and magneride shock so I don’t need a spring compressor? For a 2018 ESV Premium Luxury.
#3 ·
You need a spring compressor and the torque specs if you want to do it right. I would stick with OEM struts if you don’t want to do this again. The new struts will last twice as long as the original. GM improved the quality and they come from a company called BWI. I would look to see if your upper rubber insulator is in good condition. The bottom has an isolator which is a plastic piece at the bottom of the spring. If this is your first time changing the strut then you could reuse everything. The springs are good for 30+ years or more unless they been cut or rusted. If you’re doing it yourself then you could have a shop put it together for you for $50. Man you will fall in love with your truck once you do this. There are jounce bump stops inside the upper rubber insulator. You can buy those at any AutoZone. Everything else should be OEM. If you want to make your truck awesome after you do this change your tires for Michelins Defenders LTX and you just got a real Cadillac ride. I think the orange sticker OEM BWI struts are better then the yellow sticker originals.
#12 ·
That's definitely the right part number (I got the same number from the dealership 84977478), but that length difference is concerning... seems a bit much for normal compression wear. I know this isn't any help, but I am following this thread because I have this same repair coming up soon, and was going to buy the same part from Rock Auto.
Please keep us updated if you find out anything new. Good luck!
#21 ·
So I replaced my front struts and now have the service suspension system error message on the dash. I doubled checked everything and it looks fine and car is riding fine. Any tips on how to clear the message. I still have the dealer do oil change/tire rotation so I asked them to clear it but of course they won’t do it.
