41 - 60 of 147 Posts
I have done some checking and it appears the correct fluid is a Dexron III product like the AMSOIL ATD Torque Drive or the ATF Auto Trans Fluid.
Your should be able to confirm by going to page 6-13 of your owners manual
Just do not use the Dexron VI versions as they have not been validated (tested for component compatibility) in that year.
The ATD only come is gallons so the best choice is Automatic Transmission Fluid
So they DO still sell Dexron III then? I guess I need to change the T. Case oil asap then since it has the Dexron VI in it :(
GM has not issued a license for anyone to produce a spec. Dexron III since 2006. If you find a product that was recently produced that says Dexron III you need to understand that it may not meet GM specs for Dexron III. Dexron VI replaces Dexron III in GM automatic transmissions that were speced for Dexron III.
This info comes from GM...........
This information applies to 2007 and prior GM passenger cars and trucks.
Dexron III is being phased out as a product name. It is being renamed Manual Transmission Fluid and carries p/n 88861800 U.S. (88861801 Canada).
If fluid p/n 88861800 U.S. (88861801 Canada) is not yet available when servicing a manual transmission or transfer case, Dexron III can be used in its place.
DO NOT use Dexron VI in place of manual transmission fluid in any manual transmissions or transfer cases that specify Dexron III, as a failure may result.
- Thanks to Charles Krepp, TAC
Its possible he is not even aware of that service info. If you doubt my info, check out the source
<Source>
To get GM's approval for anything requires you to pay them a fee and royalties on every gallon of lubricant you sell. So when you see someone say its been approved by GM, it means that GM makes money every time you buy one of those products. Also, just because a lube is not GM approved in no indication its bad for the application. It just means they have not been willing to pay GM for the right to be on the approved list. And naturally GM wants everyone to think that anything not on their approved list is no good for their GM vehicle. They have a monetary reason for you to think that.
I have no idea the exact cost as every dealer is likely to price it differently. I have heard prices anywhere from $6 to $20 a qt depending where you buy it.
The following information is from the May 2007 issue of Tech-Link which is sent to all GM Dealer Service Departments each month. Read it and make your own decision! Notice what it says about un-licensed products. DEXRON is a registered trade mark and for someone to produce it means that they pay a licenseing fee and have to produce a product that meets the manufacturers specs. There is lots of money in it for the lubrication producers. GM owns the specs to DEXRON III and since they are no longer issuing licenses, no one can produce a DEXRON III fluid. Are you going to take a chance on a questionable product? Not me!
General Motors
DEXRON®-VI
Global Service-Fill Specification
figure 1
In early 2005, General Motors released a newly developed automatic transmission fluid (ATF) for the factory fill of all GM Powertrain stepped-gear automatic transmissions. The new fluid provides significantly improved performance in terms of friction durability, viscosity stability, aeration and foam control and oxidation resistance. In addition, the fluid has the potential to enable improved fuel economy and extended drain intervals. Because the performance of the new fluid far exceeded that of the DEXRON-III service-fill fluids available at the time, it became necessary to upgrade the DEXRON service-fill specification in order to ensure that similar fluids were available in the market for service situations. This latest upgrade to the service- fill specification is designated DEXRON-VI (fig. 1).
Since General Motors introduced the first ATF service-fill specification in 1949, it has been necessary to upgrade the specification periodically.
The upgrading process ensures that available service-fill fluids are of an appropriate quality for use in transmissions that have been designed around the factory-fill fluid performance.
TIP: As with previous upgrades, DEXRON-VI fluids are designed to be backward compatible with earlier transmission hardware. More importantly, earlier type fluids are not forward compatible with transmission hardware that was designed to use DEXRON-VI fluid.
DEXRON-III is not compatible with the most recently designed transmissions, and the use of these earlier type fluids could result in transmission damage. All current calibrations and certification tests are now conducted with DEXRON-VI ATF. DEXRON-III fluids should not be used for those applications where the owner manual recommends the use of DEXRON-VI.
TIP: GM does not license or support obsolete ATF specifications or the use of fluids that are being marketed against cancelled specifications.
All DEXRON-III licenses expired at the end of 2006 and will not be renewed. Beyond that date, GM will support only DEXRON-VI fluids for use in Hydra-Matic transmissions. Avoid fluids sold in the market after that date bearing claims such as “suitable for use in
DEXRON-III applications” or similar wording. DEXRON-VI licensed fluids are fully backward compatible and can be used in all applications covered by earlier GM ATF specifications.
The use of unlicensed fluids and/or non-GM approved aftermarket additives may prove detrimental to transmission performance and void warranty coverage.
- Thanks to Angela Willis
Precaution: DEXRON-VI in Manual Transmissions
When DEXRON-III is indicated as the fluid fill for manual transmissions and transfer cases, DO NOT use DEXRON-VI. Instead, use GM Manual Transmission Fluid p/n 88861800 in these components.
TIP: Refer to PIP3836B (Feb. 2007).
If the manual transmission or transfer case indicates use of DEXRON-VI, then, of course, it should be used.
Purging Equipment
Before filling your bulk fluid equipment with DEXRON-VI, be sure to purge the old oil from it.
Also, be sure to purge your J-45096 Transflow machine before using it with DEXRON-VI.
I just got done putting in mobile one in the front diff in an 04 ext, and it only took two quarts before it started to spill back out of the fill hole. I am worried because the only other number i saw was 2 1/2 quarts. I am I alright?
Ok now guys, im going to the store tomorrow to pick up amsoil server gear oil 75w90 for my front and rear diffs... wasnt to clear on what I should get for my tranny... dexron 6 castrol? or the amsoil stuff, if so which one? For the transfer case Dexron 3 or amsoil? again if amsoil which one? I have an 05 ESV of course awd with all options.. That torque drive synthetic lingo is throwing me off.. can someone clear this up? Thanks!!!! I'm having that same whinning noise in the front but when I purchased the truck I had the front bearings and diff re-done.. Now I see that these oils should be changed regularly and this was done about 10k miles ago so it might be time.. Any clue what I should do?
Torque Drive is a trade mark name for a AMSOIL Dexron III HD ATF designed for use in Allison transmissions in trucks and buses etc. While it could be used, its a HD ATF with a higher viscosity rating and the smallest size in comes in is gallons while the other products below come in qts and up.
The codes in (ATL) are the product codes. If you are buying in person look for them on rear of bottle at bar code.
For the transmission, use this AMSOIL ATF (ATL) This product is designed as Dexron VI. Dexron VI are not recommended (by GM) for use in older transfer cases, only 2007 models up. Its compatible with Dexron III in your trans.
For the transfer case use this AMSOIL ATF (ATF) This product is a Dexron III
You can check out this link to find more information on these Auto Trans Fluids----> Transmission Fluids
Btw - The 75W-90 Severe Gear Lube is the best AMSOIL has and should be good for many miles. I have over 25,000 miles on it in my 2008 GMC and I don't plan on changing it anytime soon if ever. I have used AMSOIL for over 30 yrs.
Dexron VI is far superior than Dexron III and should be used in any GM Automatic transmission that origionally used Dexron III. Fot the transfer case the lube can be very specific and I suggest a trip to your GM dealer for the latest fluid. Your Owners Manual will list a fluid, ask the dealer if there has been an update to the part number. GM does not license anyone to produce a Dexron III fluid and hasn't since 2006. If you get a fluid labeled Dexron III you can't be sure it meets the Dexron III spec as issued by GM.
Just to post a quick update on this.Went to Cadillac dealer and had them look up the transfer case fluid and the part number is Dextron IV, this is the recommended fluid. the owners manual says Destron III with H specification, and the back of the AC delco Dextron IV says it meets H specification Dextron III.
from GM service news
TIP: Any vehicle that previously used DEXRON-III for a manual transmission or transfer case should now use p/n 88861800 (88861801 in Canada) Manual Transmission and Transfer Case Fluid. And power steering systems should now use p/n 89020661 (89021183 in Canada) Power Steering Fluid.
TIP: Since some early bulletins were issued, further validation has taken place and certain transfer cases and manual transmissions now DO use DEXRON-VI, so it's important to refer to the owner manual for appropriate recommendations.
more info from GM
My 2008 GMC (GMT900) takes Dexron VI spec and a friends 2007 Chevy Classic Duramax takes Dexron IIIH spec. He called the Chevy dealer just 2 weeks ago and they told him DO NOT USE Dexron VI. I know this because he was using my phone to make the call and he used my shop to do the change.
PS-He already has 100,000 miles on his truck!
I will bring this info to my dealer to ask again. I have already changed the fluid, so I am a bit concerned. As far as the transmission goes, the 2003 Escalade manual says to use Dextron III and the 2006 Escalade manual says to use Dextron IV. Now I believe the transmissions are the same from 03-06, so what manual is correct?
I am pretty sure though that the TC in an 03 Escy is not the same as in a 2007 Chevy K2500HD. Also, Dexron VI did not exist in 2003 so it could not be shown in the manual. Dexron VI did not become factory fill till the 2006 model.
This change has caused a lot of confusion with dealers and you are likely to get conflicting info because most of them just don't pay attention to these details all the time and may make assumptions based on limited knowledge. Lots of service people are saying using Dexron VI for everything that once used Dexron IIIH but they may not be aware of the limitations in transfer cases and manual transmissions.
When you talk to your dealer service ask them to show you in writing because everything I read contradicts the use of Dexron VI in TC that call for Dexron IIIH. Here is a link to service info that might shed more info You will find the quotes I refer to in these issues.
While you say the TC may not have changed from 2003 to 2006 you really don't know as it could be something as simple as seals that are not compatible with the Dexron VI.
thanks z71 I have ordered all amsoil sythetics and when they arrive I will be draining and replacing all lubes...
Oil cleaner stuff and oil and filters will be next purchase.. But.. I will have to wait a bit....I hope this stuff is good. Its not cheap,, but then again neither is a transfer case or fron and rear end and tranny for a escalade..
Discussion starter · #60 ·
A brief update on the Mobil 1 75w140 Light truck/suv formula gear case lube.
16k miles has gone by since I put that in the front diff....
Changed it about a month ago. Came out CLEAN. NO shavings on drain plug.
So, for me personally, the Mobil 1 75w140 is all that is going in the front diff from now on....
