Battery drain - 2008 CTS
22K views 45 replies 16 participants last post by  stevem5215
2008 Cadillac CTS battery drain, two months three different mechanics. One Cadillac certified Chevron dealership. Replaced a few fuses, new batteries, passenger seat sensors. Still won't start or even let you in come morning. Almost like new but won't start. Any suggestions. Frustrated in Seattle.
#5 ·
It's back in the shop right now. When the 2008 Cadillac CTS gets back I will follow up with you. I'm hoping I can post the fix for this mysterious battery drain. Thanks for responding. If the issue isn't resolved maybe you can give suggestions for fix.
Marty
#6 ·
Seattle? Sunroof? These cars are notorious for the sunroof drains backing up and spilling water inside, causing all kinds of electrical problems.
#7 ·
If you want to find out what circuit is causing the battery drain by use of a good multi meter that allows supporting about 10 amps for current loads
As I picture below
Take off the positive battery lead cable and connect like a #14 Gage wire from it to the + of battery post
Connect both leads of meter to each side of that wire.
Set meter to Amps
Allow good 15 minutes for all controllers to go into sleep mode.
Cut the wire and turn meter on in Amps mode.
Write down what the AMP reading is
One by One pull a fuse and see if the Amp reading goes down
If not pull next fuse, repeat until you find the circuit that is putting the load on battery
May have to do this for each fuse panel the vehicle has
574998
#9 ·
As I picture below
Set meter to Amps
Thanks for your post. I'll share it with highline electric who has the Cadillac now. They guarantee they'll find the problem.
Marty
#8 ·
It has been my experience that going to different technicians will lengthen the process to find the problem if they can ever find it at all. Stay with one repair shop so they can isolate the problem.
When you go to different shop they have to start testing everything all over again.
#10 ·
Your Welcome Marty
Keep in mind with today's vehicles with several controllers that they are connected to a internal network (Starbus, or CAN or GMLAN)
When they are awake then there is a lot of current draw and can stay awake for like 15 minutes before going back to
sleep mode which then the current load drops
So when doing this type of testing do not be opening doors, etc to keep them in sleep mode
If in doing the testing the current load goes up then something awoke controllers and must wait then till
they go back to sleep mode and current load drops to then continue pulling a fuse at a time.
#11 ·
Thanks, I have finally found the issue for my 3-4 month battery drain. If you have followed my CTS 2008 Cadillac. After three different Cadillac certified mechanical shops and one specialized electrical shop. We found the problem in the passenger seat sensor. We ordered the part and after the gm strike we had a local Chevrolet certified mechanic shop make the repair. The problem still persisted with the battery drain. We then took it to another Cadillac dealership and had them review the issue. They found the installation of the passenger side sensor was incomplete. they completed the installation and now the car runs fine and the battery issue is solved. My wife's 2008 CTS Cadillac is worth 5k. We ended up paying an additional 5k after all was said and done. I hope this might help some poor sole who might go through the same nightmare. I would like to thank all of your support and help finding the cause.
#18 ·
Need to put a DC ammeter on the negative battery cable. Are four possibilities that need to be instrumented properly
  • bad battery not holding a charge
  • bad alternator not charging properly
  • bad wiring causing both of the above.
  • "something" drawing over 50 milliamps steady when shut down.
  • all/some of the above
#19 ·
Hi folks,
My dad's CTS 2008 has had a battery drain issue for some time now and I'm trying to figure out the source of the problem. If the car is driven every other day or, say, twice a week, we're good. If the car isn't driven for 5-6 days? The battery drops below the ignition requirement. The ignition switch is brand new, the starter has been replaced 2 weeks ago and the battery checks good. Now, there is a "repair airbag" message in the dash, and I was wondering if it could be linked. Any help will be appreciated
#20 ·
The condition of the battery is still questionable in this scenario. There are varying degrees of "good battery", where some are good enough to pass a descent load test after a good charge, but not good enough to hold it in a parked car for more than a couple of days.
That was the indication for the last battery I replaced, where for that reason I never let the car sit for more than about 3 days without being driven, expecting possible difficulty with starting if I did. Make sure the current battery meets the minimum CCA requirement of about 730 CCA. The age of the battery is also important, since there's no mention of it having been replaced recently.
#22 ·
I'd have your battery load tested and if you replace your car's battery...get at least as nice a battery as you had OEM...apparently CCA had changed over the years as mine had only 580 CCA and the AC Delco I replaced mine with is 680 but many other batteries (Clarios made Walmart EverStart Maxx or Interstate from Costco show 730 CCA and the Costco Interstate or the Walmart EverStart Maxx would be my choice...
Good luck with your car
Bill
#25 ·
Canadian Tire = Not the most knowledgeable service. I am not sure that I'd trust them to do a load test properly. That being said, there are good CT franchises with good people but most of them make Autozone look like mechanical geniuses.
#26 ·
I have seen the same problem with my car's battery, load test was fine battery, but the battery went dead.
I replaced the battery and no more problems.
Where does the car reside, and how old is the battery?
#27 ·
The battery is about 18 months old, it was a replacement under warranty for the previous AC Delco 48PG. The car spent all its winters inside a garage and was used in the snow a handful of times. Heck, I don't think it's been outfitted with winter tires in 5 years. Also, it has only 52k miles.
#29 ·
with 18 months of a battery not being fully charged may be your problem. Just buy a new battery for a few bucks and see if that works. Cheaper than a technician doing a diagnosis.
#33 ·
were I buying a new battery I would get the Everstart Maxx from Walmart as it appears to be the same as the Costco Interstate for about $10-12 less...I've not seen any other "premium" battery (36 month free replacement battery, plus highest CCA/CA RA) that beats that price...
YMMV...good luck with your choice
Bill
Reactions: Long
