The previous owner was a smart man to sell the car @ 89,000km. I got only 6,000km on the car before it glided to a stop after accelerating away from a stop sign. Sigh. Kicking myself for not buying a RWD model. Oh well...
That was probably me. I had a weird problem with my transfer case a while back (that sounded to me like a bearing having a bad day) and had been driving the car in RWD "mode" since.in a different recent thread, a member simply deleted his AWD system and converted to
RWD. I think the op's original statement was he wished he had bought a RWD in the first
place? What are your thoughts on this?
Well, I made one expensive mistake that I discovered after I got the car all back together. It would barely idle and was lean backfiring up the intake manifold...
I must have broken the fuel pressure regulator solenoid connector against the firewall when the engine was tilted down. Scanner code P0090 showed up in the diagnostics, which decoded to an open circuit condition on the FPR. At least it was easy to find. I was envisioning a pinched wire in the wiring harness at the back of the engine.
The good news is that once the computer got the idle under control, the motor was in low power mode and I was able to drive (albeit slowly) down the road. The tranny still shifts through the gears! 2 steps forward and 1 step back I guess.
Since I just came back from watching Finding Dory, so I'll I can say is "Just keep wrenching, just keep wrenching..."
$350Cdn + tax (not dealer sourced)How much did the replacement solenoid cost?
A brave solder from the wrench wars. Wounded, but still in active service.You've saved a few thousand doing the work yourself so just think it was a small casualty of wrench war.
Yes, once you have the transmission out of the car and on your bench, about 15 mins to get the shaft out... but go a lot slower!!! I wish I had spent more time feeling how the sections felt in their home position. I spent several hours putting it all back together and being unsure if I had the clutches aligned right with the drums. The first one you remove is the hardest to put back. The pump housing don't seat properly if you got it wrong and you might be tempted to use the housing bolts to get it that last little bit home, but don't it!!!"It took ~10-15 to dismantle the transmission and get the offending shaft out, but it took a LOT longer to get the transfer case apart. Ladies and gentlemen, I present to you the shafts of shame."
This may be a dumb question, but I assume you mean 10~15 minutes?
I bought a 2008 STS in late February, and now I have the same issue!
It is a poor design, the new ones they sell to replace it are fixed so that they won't rust etc. There's a TSB out there for it too if you want to look and learn more, it's # 10-07-30-005a ...I am going through fixing this now, it sucks haha!Hmm I wonder if I shouldn't consider pulling mine and checking for issues. is the shaft actually a bad design or is it an issue with the lubrication?
We have some shops in my area that could reproduce both ends of this and do it MUCH stronger. Would be costly though. I plan to look into this when I get a little further along so I can support lots of power but would be interesting to know what the issue actually is and if preventable without a redesign.
