Adding refrigerant to A/C...
22K views 21 replies 9 participants last post by  GailyBedight
Think my A/C has slow leak... What type does my 1996 Seville SLS take, and can I just buy the refill can from Walmart and have at it?
#3 ·
Hi,i just bought an R-134a REFRIGERANT TRIGGER DISPENSER with a built in pressure gauge at Walmart yesterday---$14.77 plus tax.
The pressure gauge is nice to have to make sure you don`t overfill.
I also bought a couple cans of the refrigerant with STOP LEAK---the stop leak really works on small leaks.
#7 ·
Like anything, you get what you pay for. You can get a cheap set from Harbor Freight that will probably do the job, but it is made offshore and has metric threads so replacement hoses and such will be hard to get. Mine is Master Cool. RobinAir is another good brand. Both have varying models and prices. Get one with a sight guage. If you have never used one, read up first and NEVER open the red high pressure side unless you are pulling a vacuum.
#11 ·
Went out and got a Master Cool gauge set with site glass and quick disconnects, ($80.00 @ autozone). From the instructions and what I've seen from the forum, I believe what follows should be the procedure to recharge the system.
Verify ambient temperature is above 65 degrees F.
1. Safety - safety glasses, long sleeves and gloves, (exposure to refrigerant can cause frostbite).
2. Attach hoses to manifold ass'y, (hi, lo, and fill).
3. Remove caps from service ports, (Low press. Larger tube from evaporator to accumulator - passenger side over fender well; High Pressure - smaller tube from evaporator along firewall towards driver's side). Verify service ports are clean.
4. Attach low press. and high press hoses to proper service ports.
5. Start car, reset low refrig code, and turn ac on high and fan on high.
6. Read gauges and compare with chart provided with gauge set.
7. If low and high press readings are both low, then system needs recharge.
8. To recharge, attach fill hose to can of R134a and slowly open low press valve, (NOT HIGH PRESS VALVE), until low press side reads 40 psi.
9. When flow stops and pressures stabilize close valves and disconnect manifold from service ports and refrigerant can. Replace service port caps.
Any comments will be appreciated. Thanks
#12 ·
Holding the can upside down will fill the system MUCH faster.
If yours has a small bleed valve in the center right below the sight glass if I recall correctly. Before you open the low side valve to add refrigerant, press the bleed valve to purge any air in the line. It should only take a brief push and you will see and feel the refrigerant come out. It will feel cold if you get any on your finger, but that small exposure will not frost bite you so don't panic. Just remember to NEVER EVER open the red high side valve during recharging.
Did you get a can tapper to connect the can to the low side hose?
#13 ·
#17 ·
i just recently had my ac bypassed by putting a shorter belt on it and i get the low refrigerent message to just wondering if this is somehting i need to worry aobut since im not using ac will it affect any other part of my motor?
No.
BigBird, where are you going to find a '60's compressor? I have heard that a compressor from a refrigerator will work as well. I was going to build one, but never got around to it. So far I haven't needed it anyway, much like the water pump socket I made, but I guess that's a good thing.
#21 ·
Making sure a system is charged properly takes more than "adding refrigerant".
While it is true that if they are slightly low, topping them off will usually do the trick, but in the long run you aren't doing yourself any favors.
Most systems newer than Y2K have added tracer dye, using a UV light will take you right to the source of the leak and then you can actually get it fixed.
System pressures can vary depending on how you are set up and ambient temperature and humidity. Charging it until it is a certain psi will not ensure proper operation to say the least, and yes, 50 psi is really a bit high in almost any weather.
On an average day you want to be somewhere between 30 and 40 psi, but that doesn't tell you what is happening in the high side of the system which can operate normally in the 100-250 range depending on conditions.
Turning the can upside down does make for faster charging, but depending on where the service port is it could introduce liquid refrigerant in the suction line to the compressor and since liquids don't compress it can tear up a compressor in short order.
To pick nits... venting refrigerant to the atmosphere is a violation of EPA regulations... any kind of refrigerant, not just R-12.
This is what I use, granted I didn't pay for it... but GM says we have to have this one to work on A/C.
http://www.thetoolwarehouse.net/shop/ROB-342000.html
Notice the price tag, that is why A/C repairs aren't as "cheap" as people think they should be.
That is a really nice machine though.
#22 ·
Agreed, EPA restricts the venting of refrigerants. R-134A is stated to not harm the ozone layer. There are circumstances where venting of refrigerants is allowed...
http://www.epa.gov/ozone/title6/608/subrecsm.html
To minimize the impact on the environment everyone should attempt to minimize the venting of refrigerants.
That being said, if the EPA was concerned about consumers use of regulated materials they would restrict their use to certified technicians only.
