hi ! , i am the proud owner of several rare cadillacs in France , but 1 of them , a 83' eldorado causes me some troubles : she only has 23 000 kms on Odo, i can quite certify to be true . Problem is , when cold , engine starts and drives as it should : low gas consumption , smooth and power . After a drive , whatever the distance , and when re-starting ( engine hot ) it starts and stops and again and again with a black smoke coming out the exhausts !. First time it happened , it did it a couple of times , but now , it does it 30 to 50 times before , suddently , running again perfectly without having done anything !. This is a non sens problem and my mechanic does not find any solution to solve it ! We already changed everything , including injectors , all candles , wires , sensors ( oxygen and temperature ) fuel pump and filters , all parts new , of course . No oil leakage , we really don't know where to look for ! default codes are 11, 15, 21 , 28 and can't be erase when using normal procedure . thank you in advance for your help and sorry for my english !
