Hey guys,
I do have a problem with my 1978 Cadillac Seville Elegante as it (nearly) stalls when hot or rather after driving for more than 30 minutes or so. Occurs especially in traffic and at low speed and many stops like city driving. I did a lot of research, checked many things and replaced e.g. all vacuum hoses as they tend to harden and brake after time. But nothing changed since then.
Lately I found a seperated pipe at the so called Exhaust Pressure Transducer that connects it to the EGR Valve (compare image below; not my car, but looks nearly the same.)
I really guess that this is the cause of my stalling Seville:
- With a broken pipe exhaust gas is leaking and
- after some time of driving filling the engine compartment more and more
- which leads to a reduced oxygen mixture
- because the engine sucks an extensive amount of exhaust gas over time.
Does that sound logical?
Well, the next problem I have is to find a replacement part! And before contacting dozen of vintage cadillac part shops and junkyards, I would like to read your opinion about that ...
... Do you see a way to fix the pipe somehow?
There is a very little hole at the transducer where the pipe should lead. Actually my parts look little better then those pictured and the pipe is still close (but seperated) from the transducer.
Thank you in advance
