2013 SRX brake pedal goes to floor
8.9K views 8 replies 8 participants last post by  Tripwire
Hi,
I have had two major incidences where my brakes completely bottomed out after hitting a small bump. The latest was on the highway while going 60 mph!!! I pumped the brake and managed to glide to the exit where I pulled into a snowbank to stop. Has anyone else had this issue? The dealership maintains nothing comes up on diagnostic! There is obviously an issue! I feel so helpless, and totally don't trust the car anymore.
#4 ·
never had them go all the way to the floor, but, I found I had excellent brakes when I pumped them a few times. Took the car to the dealer (under warranty) and they replaced the master cylinder. Breaks were great for about 4 months then the same issue again. Car is out of the extended warranty now so guess I'll just live with it unless it gets a lot worse. (2012 Performance)
#5 ·
Yeah....I was told the same thing. However, I pulled into a rest stop on vacation and as I gently stopped, the pedal went to the floor. Had van towed to dealer who replaced defective Bendix ABS. Chrysler hit with lawsuit: http://www.autonews.com/article/19950918/ANA/509180736/mo.-class-suit-targets-chrysler-abs
That ABS failure, 2 transmission failures and the paint began peeling off the car due to improper prepping at the factory (not covered by Chrysler). All within 5 years. I sold the POS and will never own another Chrysler product.
#6 ·
I would check if there's any leaks/loose lines/caliper etc. in the system first, then if all fine I would look into the ABS pump, the pump itself has valves and actuators that can cause this problem over time depends on mileage and brake fluid quality. Master cylinder is a possibility but I would look at that last. I used to work for Ford/Toyota and this guy pretty much explains it all (https://www.youtube.com/watch?v=0r46_unyYk8) all ABS systems these days are similar across most brands and are made by the same few suppliers. I haven't played around with the GM GDS2 software (their factory scan tool dealership uses) but I believe there might be functions in there the technician can test out the ABS valves manually.
Please note the brake fluid really should be changed every two to three years or 20-30k miles. DOT3 fluid is hygroscopic and over time these fluid attracts moisture the fluid will loose its ability to lubricate and prevent rust to the brake components including the ABS pump and can cause premature wear. I read somewhere the AC Delco original brake fluid might have some special additives that might push it to 5 years 50k under ideal condition but I would change it before that consider the humid climate during summer by me. When I was working at the dealership many of the brake problems I encountered can be somewhat tracked down to brake fluid have never been replaced, when brake fluid wears out it looses the ability to protect and lubricate, worst one I've seen is green algae in brake reservoir, that just tells me the brake system was mostly water.
#7 ·
Just dealt with this. I bet you were braking in slippery conditions when you it the bump. Your ABS activated, but a valve in the ABS module stuck open. The pedal goes to the floor (almost).
In my case, the soft pedal condition persisted until I turned off the car, got out, and got back in some time later to investigate. At that time the brakes acted normally until I activated ABS and the condition returned.
Brake fluid had not been changed in several years. I changed the fluid and changed the pads to a different brand of ceramic (to change the ABS response of the system). I them "exercised" the ABS system with a dozen or so attempted lock ups to verify the system was working normally again. I then bled the brakes one more time to get out any crap that could have knock out of the ABS controller.
There are electronic devices you can buy that will activate the ABS solenoids during the fluid change to help flush the module. An Ebay version I saw was about $35.
Anyway, things seem normal again. And I have since changed the fluid in my other cars.
