81 - 100 of 697 Posts
As soon as it stops raining here I will. Open the driver side door and there should be a sticker facing you. Not the one with the tire info.
That's where I thought it was, but its not on my car. I'm sure it wasn't removed because I special ordered the car and didn't even let them remove the shipping protection until I inspected.
Mine isn't there either. Just wanted to know when it was built. Just tire pressure one.
My vehicle weight sticker has the build month and year. It's just below the driver's side rear door hinge.
Yes. I missed it due to bad light and it being the color of the car.
Would be good if anyone with failed pistons could post the year and month the car was built.
Does anyone know when the ATS's started rolling off the assembly line? Not trying to hijack thread I don't want to start a thread on something so small. Mine was 8/12 and now I feel like my car isn't new anymore. It's now going on 2015.
I found it. 7/27/12 as it says on google. I knew my car was early but not that early in production.
I also believe if you want the day it was built (completed) it's on a sticker under the cup holder of the center console. Not sure how to pull the cup holder out? You can also ask your SA he can look it up by your VIN and give you a day. I PMd my VIN to RippyPartsDept (Chris/member) and he looked mine up for me 12/21/2012 just before Christmas, my sticker on the pillar just shows 12/12.
Perhaps Regals have a different intercooler design that's not as susceptible to pooling (assuming that's the root cause of these engine failures).
Question: is there driving style that can prevent and/or remedy the pooling? Would a hard run help suck it all through at a rate that won't hurt the engine? Or does hard running make it worse by increasing blow-by?
Good point you bring up. To date we haven't seen any Regals, but we rarely work on them, but there could be a less efficient intercooler so less is condensing. As far as driving, that is hard to say. If driven hard always, it may push through smaller amounts of this "gunk" mix so less chance of hydro-lock, but if there is already a good amount accumulated in the intercooler like were seeing, then a sudden hard acceleration into boost suddenly will push a "gulp" of this into the intake manifold and thus the cylinders.
What we have seen in every case of failure, is no signs of detonation, and this is in the pictures posted and the engines we have tore down, every single failure has been the ringlands broken downward from the liquid ingested, and generally the pistons that fill first from the intake air charge (the liquid fill's these first as well). GM can keep replacing engines, but until this issue is addressed at the source, this will continue.
I would like to plug into some more techs working on these and share what to look for as far as removing charge pipe and inserting boroscope in to inspect the amount of accumulation, and inspect accumulation in bottom of intake manifold.
Another simple band-aid would be to drill a small hole in the lowest part of the intercooler end caps (the plastic portion) and that will force the liquid out when running in boost....but that is a really ghetto way of doing it.
Found a few more from this and other threads not on the list yet. Tried to put it into columns to show things more clearly, not sure the formatting will be any good but here goes...
# name mileage year/model built piston(s) engine repaired/replaced
1. smurfkiller 4700 2014 ATS ??/?? #3 replaced
2. 400hpATS 4213 2013 ATS ??/?? #3 warranty would not cover, building aftermarket 800+hp engine
3. caleb bennett ???? 2014 ATS ??/?? #4 repaired
4. byrce2.0t 15000 2013 ATS ??/?? #1&4 repaired
5. shortfur7 5200 2014 ATS ??/?? #3&4 repaired
6. soop3rn0t 6800 2014 ATS 07/13 #4 repaired
7. calicts 9000 ???? CTS ??/?? #1 repaired
8. romanats 20000 2013 ATS ??/?? #3 replaced
9. ElanX 3700? 2014 ATS ??/?? ? repaired (from the other thread this looks like it was injector failed and blew a hole in the piston, maybe not the same type of failure?)
10. Shooter2384 ???? 2014 ATS ??/?? ? repaired
11. chrisgarner ???? 2014 ATS ??/?? ? replaced
12. Skenny50 6000 ???? ATS ??/?? #4 replaced
13. DB_Outlaw 12000 ???? ATS ??/?? #1 repaired, he sold car then new owner possibly had to have engine replacement
14. Firepower ATS 9000 2014 CTS 09/13 #1 repaired
15. TheRival 5500 2014 ATS ??/?? #4 replaced
16. parker133t 17000 2013 ATS ??/?? #4 repaired
17. pnm215 20000 2013 ATS ??/?? ? repaired
18. SmurfettesCaddy 16000 2013 ATS ??/?? ? repaired?
19. lemons1843 22000 2013 ATS ??/?? ? repaired?
20. LChris24 40000 2013 ATS ??/?? ? ?
Well I thought I may be in the clear, but since #6 build date is 3 months away from mine and others are going out above 20k miles, I need to stay alert.
Could this be a safety concern like a huge drop in power or just the CEl and rough idle?
mine was built 09/13, so take it for what its worth. still having car issues with mine as well...
mine was shaking sel on and difficulty driving the car
My bizzare episode included NO CEL light, NO codes stored, and dealer denial, until I had to twist some arms and then they found 78 psi in cylinder #1., seems a bit peculiar to me...more like a cover up. My ATS did the same thing, and dealer brushed it away, I got rid of the ATS in favor of the CTS so I never got to confim a bad engine, but now I am 1000% sure my ATS had a blown motor too..
SC2150 makes a valid argument for his hydrolock theory. I considered his point of view with skepticism because his theory and solution support the sale of his products. However, I think there is additional evidence to support the theory that condensed liquids in the intercooler are being ingested.
One forum member mentioned leaving his dealership and then making what I understood to be a spirited u-turn just before engine failure. It’s then possible that accumulated liquid sloshed to the exit side of the intercooler (assuming it was a left-handed u-turn) and was picked up by the air stream.
I haven’t seen the bottom of my intercooler to know whether its shape is conducive to this fluid flow. Maybe SC2150 and others can say whether this is evidence or coincidence.
