1972 Deville AIR Pump - Can I Disconnect it?
5.6K views 4 replies 4 participants last post by  Dirtywaterdiver
Hi all,
Would it harm anything if I simply took the belt off of the AIR Pump on my 72 Deville? I'm sure it's not really helping to decrease pollution at this point.
#4 ·
I've heard that you can take the pulleys from a 425 that wasn't equipped with AIR and use them on the 472 to delete the smog pump (you only really need the crank pulley). The 425 had the option of a smog pump (don't see why) and it has the same block as the 472. One of the issus with deleting the AIR, by using the newer pulleys, is that the belt routing will cause the water pump to turn slower, which may effect engine cooling. Also, the alternator will turn a little slower. You probably won't notice that until you get all of the accessories going at once. If you delete the AIR, and the charging becomes a problem, you may be able to find a newer alternator, which can create charge at lower RPM.
But really the smog pump doesn't eat a lot of your power. I wouldn't say it would be worth the power gain to go through all the trouble to delete it, and take the chance of burning the block.
