As we all know - the V2 is seriously traction limited. Sure, you can make 700+ hp, but you can't get the 556 hp, available from the stock set-up, to the ground efficiently (thus the 2nd gear start). Sport mode allows you to start in 1st gear and liquefy the tires - but does little to allow you to convert the torque into forward momentum.
The V-Sport XTS requires All Wheel Drive (the XTS is front wheel drive otherwise). This means that GM is pushing 410 hp and 369 lb-ft of torque through the XTS all wheel drive set-up. Is there any hope that they might be able to beef up the AWD to accommodate the 556 - 600 hp and 551 - 600 lb-ft of torque that the V3 is likely to develop?
Imagine an all wheel drive CTS-V with enough additional hp to compensate for the added weight of AWD..... That would really be a world class solution. What do you guys think?
