rear whine is "normal" ???
15K views 36 replies 22 participants last post by  Trapspeed
Hi Guys,
My new 2012 CTS-V sedan is at the dealers's service dept right now.
It took it there because I noticed a distinct "whine" coming from the rear of the vehicle at 40 to 50 MPH while coasting.
The service guy is telling me that it is "normal" as they took out another brand new V and it did the same thing...
He says they checked the rear fluid level and color and everything is as it should be on my car.
I'm not comfortable about living with this whine this based on some of the horror stories I read on this site about CTS-V's rear ends blowing, and the fact that it sounds like crap coming out of a 70,000 car....
What do you guys say?
Is it really "normal", or is this a major problem waiting to happen?
#3 ·
Mine started with a vibration at highway, to a whine... When driving highway, I had to do 130km/h or faster to avoid the vibrations, after sustaining this speed for 2 hours the diff started making grinding sounds at residential (slow) speeds... this is finally when the dealer acknowledged there was a problem...
I'd take it back, cause a fuss, or take it to a different dealer... Or you could try what I did... Drive on a highway that sorrounds your city at 130km/h for 2 hours... Just make sure you don't go too far in case your diff fails...
Look for my "Oscillating bla bla bla" thread, it'll detail my issues if you haven't already seen it.
#4 ·
Can you make the noise come in and out by very lightly going on or off the throttle? If so that is definitely classic differential whine. I had my differential replaced a couple of months ago under warranty and no more whine. There is a TSB out on a fluid change - the fluid now had an additive. You should have had that from the factory by now but I'd have them do the fluid change anyway. They can't really deny a fluid change when there is a TSB on that exact problem. If that does not fix it then find another dealer that is willing to replace the rear differential.
#5 ·
My 2009 V also had a whine from the day it was new. On a Friday I took it to the dealer to have it checked, they said they didn't hear anything, the following day it went south with 6,928 mi. on the clock. G.M. still doesn't want to admit they have a problem with some of the V's, it might be with the assemble, south of the border.
#6 ·
first Gen CTS-Vs were known for having diff issues (blowing up mostly due to the diff housing being aluminum - a weight saving decision that bit the engineers in the butt)
second Gen CTS-Vs have not had any diffs 'blow up' ... at least not like the first gen ... there have been issues with whine and fluid levels but other than that the 2nd Gen diff is very stout
#11 ·
Hmmm, that's unusaul, normally it's the other way around that the whine is there when you are on the gas, that's how mine is, the car only has 3300 miles on it now, it's a 2012, just got it 3 months ago. As a matter of a fact I took it to the dealer yesterday because the whining sound was getting worse, use to only notice it at 80mph and then I was really noticing it at 40 mph. Anyhow, they changed the oil with synthetic gear lube and put a small bottle of additive. The noise is still there, but I've only driven 30 miles or so with the new oil, I'm hoping it will go away with the new oil and additive, I've heard of others who have done a oil change and it did go away. I did notice on the drain plug there was a lot of sludge on it and the mechanic wiped it off, I'd definately suggest you have them change the oil in the diff though, my dealer covered the oil change under warrantee.
#14 ·
Finest- I had several minor issues since delivery and I've gotten to know a couple of the mechanics by sitting out in the shop with them. This go around I had wheel click, diff whine, and low power mode. I just told them it was whining pretty bad he test drove it 1.5 miles and deemed it bad enough to replace, along with the rotors. Seems it may be hit or miss depending on the dealership as I've read of several others with the same symptoms that have had trouble getting theirs replaced.
#16 ·
Finest, please email me anytime at Katie_Lucille@gmexpert.com if you would like me to create an official service request (case) for you and follow-up with your dealer to work towards a resolution for you. I see you've already been receiving some helpful feedback form owners, which is great, and I hope you'll keep us posted regarding your next interaction with the dealer.
Best,
Katie
Cadillac Customer Service
#17 ·
Update 8/27/12:
Upon my insistng that this loud whine cannot be "normal" on a $70,000 car, and MENTIONING THE HORROR STORIES DOCUMENTED ON THIS SITE and that I refuse to live with it in a brand new car, the service manager took it for a ride himself and just called to tell me that he hears the "gear whine" and agrees it is not normal.
He is ordering a new differential and will install it under warantee.
Thank you for all the feedback and help guys, and thank you Katie for your kind offer to get involved. :)
#19 ·
I replaced mine at 8k miles, after trying some fluid changes. The whine came back a little while later and it is still there now with 22k miles. I had the fluid changed again and wanted to have the rear end changed again but the dealership said they wouldn't replace it again. This shouldn't happen in the first place and it is annoying at different speeds.
#22 ·
I have been jumping back and forth from this forum to the Benz forum. I currently own a Benz SL550 and I have been going back and forth with the V and the C63. If you go on the Benz forum there is tons of bitching on there also about problems. For me it comes down to service. My Benz dealer is awesome and that is the only thing holding me back from buying the V. I am afraid that my local Caddy dealer will not give the superior service that my Benz dealer does. I am still leaning towards the V. I am hoping to test drive one this weekend.
#24 ·
Where are you? Get some feedback of your close dealers here...
#27 ·
I have a sales person at Fred Beans in Doylestown working on some numbers right now. They are only about 10 minutes from me. I would like to keep it local if I can. Beans does not have any on the lot so he is trying to track one down for me. I am leaning towards a 2013 unless they find a 2012 for a smoking deal.
#33 ·
Mine happens at a specific speed regardless of which gear I'm in. It's between 45-60 MPH. It becomes loud under throttle, and goes away when coasting. The whine changes pitch dependent on road speed, as opposed to RPM or gearing. All signs point to diff making the noise, last time I asked them to check it they said they didn't hear anything and gave it back to me. Now I'm experimenting to see under which conditions it's the loudest, so I can recreate it for them.
#34 ·
From post #5.............
My 2009 V also had a whine from the day it was new. On a Friday I took it to the dealer to have it checked, they said they didn't hear anything, the following day it went south with 6,928 mi. on the clock. G.M. still doesn't want to admit they have a problem with some of the V's, it might be with the assemble, south of the border. It got replaced
#36 ·
I had a rear-end diff type metallic noise, not so much a whine. After 2 disaster service visits with a local dealership where they drove my car 55 miles, changed the radio station to a rap station, I took the foreman for a ride to show him the noise and they still drove it 37 miles (included in the 55 total miles), I took it to another local dealer. I dropped it off in the morning with squeaking/groaning front brakes and the rear-end noise. I picked it up 8 hours later with a brand new differential, new front 2-piece rotors and new front brake pads. They put 7 miles on the car to identify the sound.
Suffice to say I am NEVER going back to that other dealer and will be going to this new dealer forever. Anyone in DFW, I HIGHLY recommend Sewell Cadillac in Grapevine. Talk to Bill Wilmut.
