Depends if the bolt pattern, offset, and hub center are the right size. Bolt pattern is 5x114.3, offset is +40mm I believe, not sure on the hub center but I had to have my rims machined out a little bit. 235/55/17s are a little over half an inch taller than stock 225/60/16s, meaning if your speedo says you're doing 65, you're actually doing 66.34mph. Which isn't really enough to be concerned about.
