2008 STS-V
I'm looking to add the additional heat exchanger as many have done on here. I see a few people with the frozenboost 101 and others with the ZZP unit.
The ZZP unit appears to be 2-pass according to the website, but from others I've seen on the internet, it looks like its a single pass. Reading the website, it can be ordered in either configuration.
Its dimensions are:
27 3/4" wide x 6 1/4" height x 2 1/16" thick
The Frozenboost certainly has both fittings on the same side, and is a 2-pass.
Its dimensions are:
26" wide x 7" height x 3.5" thick
All in all, will these perform equally, and will any difference even be worth considering?
Code:
           Width     Height   Thick
ZZP        27.75      6.25     2.0
FB         26.00      7.00     3.5
2013 OBM CTS-V Coupe
With either one the big difference is the cooling aspect. Or should I say the time it takes to get from WOT to normal temps.
It does make it easier. It is a personal preference. I have the Flex-A-Lite 45321 (6 pass) that replaced the stock and added the Frozen Boost 101. Living in AZ I haven't had any issues in the summer heat. I usually run 20-30* above ambient for IAT2 temps but I can run back to back WOT runs within a minute of each other with the upgraded pump. The temps drop really fast and are back to normal within a minute.
