Hey guys, new to the forum. I just purchased ZZP Stage 1 for my 2014 ATS 6 speed auto. After installing the PCM, my car has been stalling when I slowly turn into areas ( parking garage, gas stations, etc). Have y'all had any issues with stalling and weird idles when going low speeds?
I turned into a gas station and it stalled so I had to put it in park to turn it back on. Anytime I go 2-3mph and make a turn it starts wanting to stall. Any help would be appreciated.
Thanks!
ATS
Is the check engine light on, do you have the cold air intake make sure the pod is correctly installed
No check engine light. Yes, I have the ZZP cold air intake. Everything is properly installed.
ATS
If the pod is a new one possible oil got onto the maf sensor, next step I'd say clean maf and double check connections. I had an issue like that once, for me the filter wasn't in all the way so would drive fine but die when I went to idle, otherwise contact zzp they're pretty good at helping with trouble shooting.
