Xenon-Vision HID Conversion Kit (September Special $130 SHIPPED!!!!!!!!!! ENDS 9/30/07)
Available in 9003/9004/9005/9006/9007/9008/H1/H3/H4/H7/H10/H11/H13/880
You may order the HID Conversion Kit from our website www.xenon-vision.com
Please use Customer Code "caddy907" at Checkout to receive the group buy discount
Xenon-Vision Gallery
We do our group buy differently from most vendor. Most vendor will require 10 to 15 members to make the purchase and they send out the product after the group buy is over. We will however, send out the product within 24 hours of receiving the payment, if the correct bulb size and color is in stock.
Flicker harness $30
Flicker harness or other might call it the BMW harness is known to get rid of the flickering issues or headlamp error light issue. This issue is known on most European cars (BMW/BENZ/AUDI) and now it is occur on some American cars (CHRYSLER/DODGE). The reason behind this is due to halogen bulb being 55W and HID is 35W. Therefore, when an HID kit is installed into the vehicle, the car ECU detect the lights running at 35W instead of the normal 55W. Two things will happen when it detect this. 1. When running at 35W, the ECU thinks the light bulb on one side is broken and cut down on the power it sends to the headlight, causing the HID to flicker because there is not enough power. 2. It will cause a headlight error light on the dash because it think 1 side of the headlight is broken. One or both of these issue will occur. The flicker harness will plug inline with the ballast (Plug and Play harness). The flicker harness will trick the ECU into thinking the HID is running at 55W, when it is really running at 35W. This will trick the ECU into thinking that both side of the headlights are working fine and give the headlights full power, which will get rid of the flickering issue and error light issue. This harness is safe and will not damage any ECU or electrical wiring.
*Caution: Capacitor on harness will heat up, please keep handle with care
**Harness need to be connected with the correct + / -, connecting with opposite - / + will be damage capacitor
Payment Method: Credit Card over the phone/website, Paypal, and Money Order/Cashier Check. Local Pickup Available for Southern California Resident.
You may contact us at 626-698-6753 or call us toll free at 1-866-718-7583. If you wish to pickup, pay over the phone, or if you have any questions. You can also contact us by PM or email us at [email protected]
Please use Customer Code "caddy907" at Checkout to receive the discount
3000K - Golden Yellow (Picture Below)
5000K - Crystal White (Picture Below)
6000K - Crystal Blue (Picture Below)
8000K - Blue/Purple (Picture Below)
10000K - Deep Blue (Picture Below)
12000K - Violet Purple (Picture Below)
Xenon-Vision HID Conversion Kit is a True Plug-N-Play Kit. Our conversion kits fit into your headlight housing perfectly. No modification or retrofitting is required. No need to cut your stock headlight wiring. Our kits is made so that it all Plug-N-Play.
Just connect the wiring harness from the stock headlight wiring to the ballast. From the ballast, connect the wiring harness from the ballast to the HID Bulbs. Put the HID Bulb back into your headlight housing and your done. Detailed instructions will be included in the kit.
Features
True Play-N-Play Conversion Kit
  • Safe for headlight and fog light, won't melt the housing, runs cooler than stock halogen bulbs
  • Brighter driving vision at night
  • 3 times brighter than halogen bulbs
  • Fits into existing headlights or fog lights, no modification or retrofitting required
  • Nice color output with a hint of blue or purple (6000K Kit and higher)
  • 35W power consumption compare to 55W halogen bulbs
  • Bulb Lifespan of 3 to 5 years
  • ISO9001 Certification and European E-Mark for 100% guaranteed product quality
  • Ballast has shut off mode, to prevent a fire or damages if a glitch occurred.
  • Ballast and Bulbs is Waterproof and Shockproof
  • Waterproof connectors and grommets
  • 1 year no hassle warranty on bulbs and ballast
Please use Customer Code "cadillacforums" at Checkout to receive the group buy discount
