1 - 10 of 10 Posts
~2011 CTS-V Coupe & 2013 SRX~
I meant to post this a few days ago.... The other day, as i was under the "V" doing the spectra bushings..... I said to myself.... This is a good time to change the oil and grease the front end. I start feeling the lower balljoints grease boot and noticed it felt emty.... I start looking around for a grease fitting to fill er up, and could not find one..... Am i missing something here? :confused:
'05 CTS-VM 51 track days in Maggied V & 82 in Atom 2 in Volt
The lube is inside joint, big ole gob of grease under the boot would have indicated too much grease in old school joint. Plus it used to make a mess under car. Progress is good.
CTS-V
I had front-end groan at full lock either direction. All the dealer could do was spray down the stock anti-roll bushing with white lithium. Installing the Hotchkis with trusty zerks cured that little problem.
Not having to worry about grease for the front end makes servicing the car a lot easier and quicker (just change the oil/filter and check the other fluid levels). I think it's wonderful.
1 - 10 of 10 Posts
