1 - 20 of 20 Posts
I'm just wondering if any of you are having similar problems or have even heard of this.
It started with my driver side door I stick the key in and cant turn the lock at all. Now I cant get the trunk open either except through the inside. Now everytime i get in I have to walk around to the passenger side and unlock my car I'm just trying to solve this problem before all my locks crap out and im stuck out of my car.
Also are you supposed to be able to lock your glove box? If so that doesnt work either.
im guessing its because of the cold try lock dr-icer on them or at least lube them up a little
You may end up needing to pull the door panel and inspecting the linkage. Depending on the mileage, it may be somethng like a groove worn into the mechanism causing the lock to hang up. To check, disconnect the lock rod and see if the key works. If it does, its the mechanism. If it doesnt, its the tumbler.
Discussion Starter · #7 ·
what exactly is the lock rod how do i get the lock out of the door? (isnt there metal in the way?)
94 Fleetwood Brougham
GM is dead against WD-40. The solvents in it destroy the protective coatings in the lock making it prone to sticking and failure. I know, my Suburban had ALL locks frozen when I got it. I got 2 freed up, and one I still haven't been able to. The tumblers got stuck in the up (or down) position, where it had bene pushed too far.
GM recommends motor oil.
90Brougham350 said:
Put the little red nozzle on a can of WD-40, fits perfectly into the lock hole.
Sounds like a tumbler got stuck. Squirt some 5W30 or some motor oil in, and then move the key up and down while it is in. Keep working them tumblers and see if it frees up. If it just did it, it might loosen up just as easily. If you leave it it may stay that way for a long time!
You can use sewing machine or 4 in one machine oil too, that is also recommended. They often has small bottles that fit well. WalMart sells a small bottle in the automotive dept that has a nice long extension on it that will get in there. Just prop open the little flapper and dump some in.
It took me a while to get my Suburban locks to loosen up, and I broke the crappy pot metal retainer on the drivers side banging on it (don't do this, it does nothing bur break things.... I thought my key wasn't going in far enough...)
The pass side just took time. The rear now, I STILL can't get loose. I have been at it around 1time a month for the last year....
1 - 20 of 20 Posts
