would bad hg's cause the lower radiator hose not to get warm??
just wondering....
just wondering....
----------------------------------------------------------------------Coolant circulation problems cause the lower hose to stay cool after warmup and (maybe) thermostat - open.
Coolant circulation problems are caused by insufficient coolant, bad thermostat, no thermostat, clogged radiator and/or hoses, and a malfunctioning water pump.
Until the entire Northstar cooling system gets to over 188 degrees the lower hose will stay cool. Only after engine block coolant above 188 degrees starts to flow through the radiator will the lower hose begin to warm up. ??? If the radiator were 100% efficient, the lower hose water would return to the water pump at ambient air temperature.
ya, that makes sense, air doesnt cool very well. my radiator is cool as well, with both fans running. i tested the car for combustion gasses in the antifreeze and it didnt turn yellow, sort of blue/green, tires plus tested it and they said it was ok, then i took it to the shop where its at now and they said it was positive.When my headgasket went the temp would spike up going up a hill. When I would pull over, even though the display said 245 or so, the radiator was cool, both fans would be running. I think the system was getting airbound after the combustion gas displaced the coolant, and the water pump would stop circulating. Was a tiny spot on number 1 cylinder where the gasket was leaking.
Whereabouts are you located?ya, that makes sense, air doesnt cool very well. my radiator is cool as well, with both fans running. i tested the car for combustion gasses in the antifreeze and it didnt turn yellow, sort of blue/green, tires plus tested it and they said it was ok, then i took it to the shop where its at now and they said it was positive.
anyone want a very nice bronzemist '01 dts??
central wisconsinWhereabouts are you located?
