If the crank pulley wobbles perceptibly, you run the risk of throwing the serpentine belt at highway speeds or greater. Maybe the rubber/elastomer damper has deteriorated.
Not a difficult replacement, through the fenderwell with the wheel and plastic well liner removed, BUT the crankshaft bolt torque procedure is absolutely critical as the crank pulley hub bears on the oil pump (which is wrapped around the crank snout) and supplies the clamp friction to drive the oil pump. The main difficulty is that the crankshaft must be locked for the procedure to work correctly, and that involves removing the intake manifold and starter (under the manifold) in order to lock the teeth on the flexplate. (The manifold is dry, so there's no coolant or weird seal/gasket problems there........)
