1 - 8 of 8 Posts
2000 Deville DHS
Hey guys. I am having a major issue. For some reason my windshield wipers wont turn off. Someone mentioned that my rainsense sensor could be malfunctioning. Does anyone know exactly where its located on a 2000 DHS so I can just try disconnecting it to see? Please help guys! I really appreciate it.
Do the wipers run constantly or do they sweep once in a while ? The stalk has 5 positions - from bottom to top: spring-loaded single sweep, OFF, Interval/RainSense, SLOW, FAST. make sure the stalk is in the OFF position.
If the stalk is in Interval/RainSense, then any moisture and/or dirt or obstruction on the windshield in front of the sensor patch (in front of the mirror) will cause the wipers to either cycle once in a while or frequently, depending on the interval set by the ring on the stalk. This position will also give you oddball "Headlamps Suggested" warnings in the DIC.
2000 Deville DHS
its very varying. It goes once every 5 seconds or so... then speeds up... then slows down. It seems like I am having a problem with the rainsense. I disconnected the plug at the stalk inside the steering column, and they still ran. I have to safely assume that could be my issue. Do you by chance have a picture of what this thing looks like? I have quite a few little sensors on the windshield, and am not sure where I would find the plug to disconnect this bastard. lol.
2000 Deville DHS
Discussion Starter · #4 ·
or... possibly the color wire I could trace back the the motor itself, and cut it to stop the rainsense sensor from sending the signal to the motor?
I don't have the '00 Deville schematics - look at a subscription to www.alldatadiy.com - that's the GM shop manual plus a LOT more online.
2010 DTS
The Rainsense sensor is the black box at the top of the windshield next to the mirror. I suspect you may have a bad column switch. That happened to my daughters '02 SLS and I had to replace the switch.
1 - 8 of 8 Posts
