2006, 2014 CTS, Currently 2018 XT5
I went to a couple of parts web sites hoping they may have listed the capacity but no luck. The manual only has the cooling and oil capacity.
Other then running it dry and then refiling it out of a gallon jug to see how much it takes is the only idea I have.
none
Discussion Starter · #4 ·
I'm pretty sure it will take at least a gallon, so if you mix a gallon and then pour it in you should be ok.
Ill prob do that !...
Since 1 Gallon = 3.8 Liter
Ill see how much it can take and let you know !...
btw, the wipers on the CTS sucks, simply cleaning with water will leave your window streaking (both sides), and I had 1 wiper replaced but it streaks will just happen with only water !..
none
Here is the thing, the Cadillac CTS will take MORE than 4.8 Liters for sure as I just topped it up with that amount but it was NOT totally filled, not sure how much more though it can take !...
