TRYING TO FIND A CHEAP OPTION FOR SOME WINTER TIRES ON MY 2013 CTS PERFORMANCE AWD SEDAN... CAN I DROP DOWN TO 18'S WITHOUT SCRAPING ANYTHING? SHOULD THESE FIT?
www.varagesale.com
I TRIED TO INVESTIGATE AND IT LOOKS LIKE THE OFFSET WOULD BE 5MM DIFFERENT AND THE OVERALL DIAMETER WOULD GO UP A CM... THAT SHOULD STILL WORK RIGHT?
www.wheel-size.com
www.wheel-size.com
I'M PROBABLY OVER THINKING IT, BUT HAVE ALWAYS SWITCHED TIRES BACK AND FORTH ON THE SAME RIMS PREVIOUSLY.
Winter Tires - BMW X3
245/50R18 Set of four Kumho winter tires (not studded) with custom ordered rims. Used on a 2016 BMW X3 28i for a few seasons. Aprox 8/32's tread remaining.
Cadillac CTS 2013 - Wheel & Tire Sizes, PCD, Offset and Rims specs
Cadillac CTS 2013 - Find out the correct alloy wheel fitment, PCD, offset and such specs as bolt pattern, thread size(THD), center bore(CB) for Cadillac CTS 2013
BMW X3 2016 - Wheel & Tire Sizes, PCD, Offset and Rims specs
BMW X3 2016 - Find out the correct alloy wheel fitment, PCD, offset and such specs as bolt pattern, thread size(THD), center bore(CB) for BMW X3 2016
