2002 Cadillac DTS Deville on Vogues and DTS Blades
will 2003-2005 dts side mirrors with stock arrow blinker work on a 2002 dts without stock arrow blinkers
what would i have to do to the side mirror connections since i know the 02 dts connections did not have one for the blinker?
'98 STS (RIP @ 206,xxx miles)
That will be the tricky part. You will have to locate the two turn signal wires that connect to the rear lamps and tap into them to feed the respective mirror. The wire bundles are buried in a channel that is accessible by lifting the door sill trim piece. I have found that both the right and left turn signal wires will be in the same wire bundle.
The factory Service Manual published by Helms will be a necessary tool.
You will also have to modify or fabricate a connector to match your new mirror glass to the existing car wiring. Plus add a connection for the turn indicator at the mirror.
