UpDate : It appears we have No problems, the Maps are now working properly , it must have been the area we were in because it was out in the sticks BUT there are side roads that I thought should show up on the Map like County Roads 17A and 17B which takes you into US-441 a Main road. But then again I loose Cell phone signal for no reason out there too, sometimes it works and sometimes it doesn't.There must be something out there that doesn't like radio waves or GPS signals. Anyway the Dealership checked the Map Nav. sys. said no problems that they could find.
The Hatch re-open problem, No Problem found there either. Dealership said it just takes a bit of heavy Pressure to make it re-open, to ME it's to much pressure, should be more adjustable, also they took my wife to 2 Different SRX's on the lot and showed her each one had about the same pressure to reopen the hatch as it was coming down. They also showed her the rubber area near the tops of each SIDE of the Hatch that also triggers the reopen. I still think it requires to much pressure for a re-open, It scares you more than it hurts because you are wondering if it's ever going to re-open. Anyway, car was checked out and everything is working up to GM par.
