1 - 20 of 24 Posts
i noticed that there is a 8 inch circle where a speaker should go in the reat drivers side. whats up with that? is that an option? i thought i got the dvd option with all speakers. i noticed on the web site that it said 9 speaker but then i only found 8. am i missing something?
also can i put a subwoofer there? can i use a after amrket amp or will it make the hissing noise?
First off, I think you have 9 speakers, since there is a small (very) sub-woofer in the center console that you don't see (I am told). But, I was wondering the same thing - can we add a sub to that back speaker mount hole??? If you learn anything let me know, and I will do likewise
I Added An 8" Jl Audio Sub In A Custom Enclosure Behind That Panel Then I Took Out The Plastic Grille And Had A Custom Grille Skinned In Grille Cloth That Matches The Interior.
I Added A 150 Watt Amp To Power The Sub And It Is Wired Into The Stock Bose System. The Result Was The Bass The Car Should Have Had From The Factory And A Factory Look In The Rear.:thumbsup:
I believe there is a subwoofer there in the Tahoes or Yukons.....
Since they use the same part in the Escalade it is empty due to the fact that the subwoofer is located in the center console...
********Please Post pics of the subwoofer installation in the rear hatch.*********
all nbs gm suvs...escalade tahoe etc...had the sub in the rear from 01-02...then GM got smart and put the sub up front but got lazy and didnt make a different panel for the the rear...so now all the 03+ owners have a speaker grille that covers no speaker...
2011 ESV Platinum and 1976 Eldorado Convertible
That certainly explains why I have been disappointed with the bass coming from the "premium Bose sound system" in my 2004 ESV. So where exactly is the tiny sub located in the center console? Also, do you think it is better to consider upgrading that one to a larger sub or adding a second sub with an amp in the rear?
I don't think the subwoofer is mounted in the center console.
The BOSE Amp is in the middle between the front seats. And as advertised by Cadillac it seems that the subwoofer is also there.
I am very satisfied with the bass power I am getting and I don't think I'll ever add a speaker to the truck.
2012 CTS, 2009 Escalade ESV
Quote:"I don't think the subwoofer is mounted in the center console.
The BOSE Amp is in the middle between the front seats. And as advertised by Cadillac it seems that the subwoofer is also there."
Isnt the center console the thing between the two front seats???
atomikorange said:
MEJIA - Here's a pic of my 8" JL Audio sub in the rear....
Thanks for the picture......
What amp do you have the subwoofer wired to?
I believe you had to buy a "special interfase" to make everything work with the stock system right?
If so, what brand and model is the "so called" interface, also price and where to buy it will be great.
Once again thank you,
Mejia
Okay... I was confused between the center console and the front console I guess.
Mejia
8" sub is a JL Audio W6 = $315.00
Amp is also a JL (250x1) = $429.00
The interface / adapter = $99.99 (not sure what the brand is, but you local audio shop should have one.)
And to answer Sycosis's question - There was no existing wiring.
Overall the added sub is a great "addition" to the Bose system and it does sound good. But if your looking for that thump you need more. I'm planning on upgrading to (4 )JL 10" subs in the future.
Hope this info help.
1 - 20 of 24 Posts
