1 - 2 of 2 Posts
2003 Seville
My traction control light came on then service electronical system light come on and now my radiator fans aren't working any suggestions would help
On a 2003 Seville
Welcome to CF !!!
Battery connection problems?
Our cars have their own built-in trouble code and diagnostic scanner. You use the 3 buttons just right of the DIC to enter and use the system.
Study the correct section (by JimD) in the sticky thread "How to pull codes". They print out as a letter, 4 digits, a letter suffix. Define the codes using the embedded OBD-II link and post it all here.
Cooling fans go to SLOW at 224 degrees, FAST at 236. They run in SLOW when any HVAC A/C compressor function is set.
Here's your temp gauge and fan settings.
1 - 2 of 2 Posts
