Do you have the dome override switch turned on? It's next to the headlight knob.
I had the same problem. The round stub that you push in and out is NOT the dome override switch. The round stub/knob only adjusts the relative brightness of the panel lighting. Directly above the round stub/knob is a square shaped switch that looks like it is just part of the panel, it is actually a switch that you push in to keep the dome lights off, and push it again and it allows the dome lights to work. Duh :thumbsup:
Below the round stub/knob is the switch for the fog lamps, and it works the same way.
The owners manual is not clear on these two switches and I had a friendly tech at the dealer laughing at me. (He said a lot of people have been back with the same question, I think he was just trying to be nice and not call me a dummy.)
Hypo
02' to 06' are different than the 07's.I had the same problem. The round stub that you push in and out is NOT the dome override switch. The round stub/knob only adjusts the relative brightness of the panel lighting. Directly above the round stub/knob is a square shaped switch that looks like it is just part of the panel, it is actually a switch that you push in to keep the dome lights off, and push it again and it allows the dome lights to work. Duh :thumbsup:
Hypo
Another example of how awesome this forum is and the wealth of good information that helps fellow members not look silly at the service department.I had the same problem. The round stub that you push in and out is NOT the dome override switch. The round stub/knob only adjusts the relative brightness of the panel lighting. Directly above the round stub/knob is a square shaped switch that looks like it is just part of the panel, it is actually a switch that you push in to keep the dome lights off, and push it again and it allows the dome lights to work. Duh :thumbsup:
Hypo
