1 - 20 of 30 Posts
There is a ton of rims that would look awesome on the v but they are usually a one of the 5 lug patterns. WHY DO WE HAVE 6 lugs?????:suspect:
Does anyone know if there are kits that change the lug pattern???
I know it is a silly question but it would make rim choice HUGE and less expensive, as long as the spacing offset and size is picked correctly.
Because the machinist was to lazy to do 7, one for each spoke? :histeric:
I don't believe there are any kits that will effectively change your bolt pattern. Dual pattern spacers/adapters are thick - and there simply isn't enough offset to begin with to make it work.
Good luck.
Wait a minute..."LS6" must stand for Light Silver 6 (lug wheels) ;)
That's mean the '06 is only going to have 2 lugs...better threadjack and ask where those pics of boobs went :canttalk:
:alchi:
I'm doubtful that too much torque is the answer. It is a curious decision on GM's part for the 6 lug wheels. It could have purely been marketing for their own line of rim options, at least while the aftermarket catches up. It does make their pricing seem less absurd when the aftermarket is getting $1K+ per wheel.
Personally, I'm holding out for the "LS7" wheels (one for each spoke, you know?) :suspect:
Premium Member
1975 Seville; 2004 CTS V; 2011 CTS V Coupe
Six lugs is just like every other Bulls.... idea to make a specific GM product. The Memory feature, which would automatically reset when the #1 or #2 Key Fob was used to open the door on our Corvette. In the CTS V, you must push the 1 or 2 button on the door. Logical; NOT!
The CTS V Navigation System. The V comes with the base CTS Navigation manual; The V Navigation System is modified to operate differently. Therefore, the CTS manual is of marginal use. Base CTS Center Console is utilitarian and comfortable to use. In the V, a specific redesigned Console is obviously built on the cheap, wide open and less that durable.
So, why not install a Six (6) lug wheel so that one's aftermarket wheel choices can be counted on one hand. Why put a car on the road that can be personalized and become conspicuous to other possible car buyers as an exciting automobile to own. :banghead: :banghead:
Lemon Law'd '05 V
As I've heard...Ford had a few secret agents infiltrate the GMPD design/engineering team and decided to sabotage the best car GM's ever produced. First they started with the shifter..."lets make it almost impossible to get into reverse". Then someone decided to "rubber mount the rear cradle..yes, major wheel hop, yes...so they'll never be able to really launch the car"....which led another really twisted Ford agent to add "and we'll spec an underrated differential that will whine,howl, and pop". The suspension agent added "self-leveling rear suspension so they'll never be able to drop the car or add stiffer springs without taking out a home-equity loan...AND they'll suffer major embarassment by unsightly wheel gap".
Lastly, when they were exhausted thinking about ways to thwart the V...someone brought up the 6 lug wheels..."six lugs...Hahahahah...yeah, six lugs.....so they'll never be able to buy real race rims....just polished/chromed/blingity forged rollers...hahahaha...............AND RUN-FLATS...HAHAHAHAHAHAHAHAHAHAHAHAHA"!!!!!
And there you have it....the real reason why we've been tortured by GM.
F'the six lugs,
ace996
I actually like the 6 lugs. I just wish there were more affordable wheels out there for us. I doubt the aftermarket will ever "catch up" with this due to our limited production.
And for the record I agree with ACE. I'm down for any conspiracy theories. :thumbsup:
Discussion Starter · #10 ·
:histeric: yeah so many things seem absurd but in the end the car is still sweet!!!
The iforged rims are around 900 a piece without tires and to make it worse you go on ebay and you can find practically a new set of iforged or hre for aorund 2500 with tires. 19's 20's 18's whatever you desire and then you remember
" I have 6 not 5 lugs":banghead:
In those year v's there was to much power going to the rear and it was snapping the studs so they went to a 6 lug pattern. After market wheels are not cheap!!!!! I bought a pair for my 2004 cts v cost me 7200.00 . Now you can go to Carid.com they sell wheels now for alot cheaper. hope this helps!!
1 - 20 of 30 Posts
