1 - 13 of 13 Posts
I was running a Northstar in my rock buggy up until last week when it tossed a rod through the valley right under the starter at just above idle.
I assume I damaged the motor earlier maybe from an overheat up to 260 for about 10 miuntes(fan relay failed)but the oil never went to cream and it wasn't using coolant so I thought I was ok.
Now I am gun shy about replacing it, and I am thinking about a supercharged 3800 series 2.
I am pretty sure the abuse I give the motor had something to do with it, but I have seen 2 others in junkyards the same way still in the car.
Premium Member
Northstar rods are about as exotic as stock rods get. They are powder forged with cracked caps. You must have been turning about a jillion RPM.
98 sls Northstar
Thanks for the info, 2dedge. I couldn't reply because I am not yet allowed PM's yet. I'll tell you about my setup if I can get through to you somehow, you could email me at dan (at) glenellenlabs (dot) com.
Discussion Starter #10
Well after further research it destroyed the piston and the schrapnel came through the block not the rod.
'03 STS 122K, '01 STS 161K - 3/3/11
pics?
I've put the pic of your buggy up on my work computer and everyone loves it.
The Northstar Tuner
let me guess you have been using a Commander 950? Don't feel bad I hear about this type of thing with them and the Fan Thing also
1 - 13 of 13 Posts
