1 - 19 of 19 Posts
2006 CTS-V
And yes I did search. Ive been out to sea though and it seems yourgmsolutions is not doing the clear covers anymore? Am I looking in the wrong place or is nobody doing this mod anymore? Made friends with a semi retread and need to replace the cracked lense covers. Thanks, Max
Tis Gone :(
If i can get my lazy ass off the couch I plan on taking my bumper off today and doing mine.
3 to 1 it wont get done.
04 CTS-V with a little hp persuasion device
no fog covers being made that I know of
05 PLATINUM CTS-V
if this is true looks like i will be stuck with yellow for ever
If you're handy, you can make your own!
05 CTS-V / 06 Escalade
Im VERY close to getting a shop to Make me a Set - I just need a spare set of housings for CHEAP!
I have the lens's off my Housings, but I want to make sure the fit is right, and air tight - So I need a set of Housings to test fit them. If it all works out, I would def. be selling them here (Yes I would become a Vendor as well!)
04 CTS-V
someone in the classifieds had a set for around $40 a few weeks ago
VRod. I think I have my stock housings 100% stock with the lenses on still in my garage.
REALLY!! Let me know!
Hey Vecstacy you coming up for the Meet and Drive on May 31st?
Huh? Where they YGMS? I never saw them - and I usually check the classifieds often.
Silver '05 V
You guys can do this yourselves. This was the first project I undertook in parallel to the free flow intake tube.
Took me about 45mins to get my fogs out of my car. You don't have to take the bumper off. (2 beers)
Took 10 mins to bake the lenses off the housings, low heat.
5 mins to fill the channel on the housings with glue.
Let glue setup for 1 hour. While glue was setting up moved on to next step.
10 mins to make a template of the lens (use card stock). (1 beer)
15 mins to cut both lenses. Used a good dremel cutting wheel. (1 beer)
When glue in channel is setup, glued fresh cut lenses on. Clamp/taped the sh!t out of them to make sure contact all around, 15ish minutes. (1 beer)
Sat in hot tub and finished case while lenses sat over night. In the morning did the ever so important submersion test. Didn't want to find a leak first time I washed the car. (1 bloody mary)
Reinstalled fogs and searched for scattered plastic tabs for the wheel wells, 45 mins.
So for approximately 3 hour/5 beer job, most could do it in an afternoon. The lexan for the lens was about $10 at the local Lowes. I already had the dremel.
I got (sorry for the phone pic):
04 CTS-V
no these were factory housings. someone maybe you i dont know...dont feel like hitting the back button said if they could find some cheap housings they might get into making these
2006 CTS-V
Discussion Starter · #13 ·
Thanks for the responses, that is what I thought. Guess I will have to do it myself
2010 Thunder Gray 6MT
Very nice! I need to do this...
So what to you guys do with the little rubber trim that goes between the lense and the bumper cover?
2005 Platinum CTS V-Headers+3in pipes
Luv, what bulb do you have in your DRL's?? Silver stars??
Not going to be able to make it on the 31st. I will check on Thursday or Friday in the rafters and work out how to ship them to you. It is the least I can do for not swapping fogs with you. :thumbsup::thumbsup:
Awesome!! Thanks!! Shoot me a PM ill give you my info. :highfive:
1 - 19 of 19 Posts
